Add extra ChartValueList on TLineSeries
Lenfors
Post by Lenfors » Wed Jan 27, 2010 2:16 pm
Hello!
I have several TLineSeries containing lots of data. Now I would like to filter the "visible" data y-serie but still keep my original values.
Of course I could have duplicate TLineSeries one containing the original data (invisible) and another TLineSeries containing the filtered data, or a separate array containing the original. The proble is my project is huge and this would generate changes all over!
My ide is to add a a ChartValueList to the TLineSeries and save the original data there, is this a good ide?
ChartValueList := TChartValueList.Create(Series3, 'UnFiltered');
Series3.ValuesList.Add(ChartValueList);
Now Series3.ValuesList.Count reports 4! I thought it would now be 3, X, Y and UnFiltered!?
Then I load my original data:
For I := 0 To Series3.Count - 1 Do
Begin
Series3.ValuesList[2].Items := Series3.YValue;
End;
Do I have to dimension the Items array before assigning data?
All this seems to worke fine, except for one thing. When I close my application I get an EInvalidPointer exception.
Any ideas?
Regards, Mikael
Re: Add extra ChartValueList on TLineSeries
Post by Yeray » Thu Jan 28, 2010 3:18 pm
Hi Mikael,
Here is how I found that this could be done. Please note that the sentence Series3.ValuesList.Add(ChartValueList); is redundant as you've already given the series to the TChartValueList.Create method.
var ChartValueList: TChartValueList;
    i: integer;
  Chart1.View3D:=false;
  Chart1.AddSeries(TLineSeries.Create(self));
  Chart1[0].FillSampleValues();
  ShowMessage(inttostr(Chart1[0].ValuesList.Count));
  ChartValueList := TChartValueList.Create(Chart1[0], 'UnFiltered');
  //option1: copy all Y values to the new valuelist at the same time.
  //Chart1[0].ValuesList[2].Count:=Chart1[0].Count;
  //Chart1[0].ValuesList[2].Value:=Chart1[0].YValues.Value;
  //option2: copy all Y values to the new valuelist one by one being able to modify them.
  SetLength(Chart1[0].ValuesList[2].Value, Chart1[0].Count);
  for i:=0 to Chart1[0].Count-1 do
    Chart1[0].ValuesList[2].Value[i]:=Chart1[0].ValuesList[1].Value[i]/10;
  ShowMessage(IntToStr(Chart1[0].ValuesList.Count) + ' valuelists // Y value 0: ' + FloatToStr(Chart1[0].ValuesList[1].Value[0]) + '// extra value 0: ' + FloatToStr(Chart1[0].ValuesList[2].Value[0]));
