Can I paint graph with gaps for TCandleSeries?
Hello. Can I paint graph with gaps for TCandleSeries in CandleStyle := csLine mode? AddNull method doesn't work. Example is attached in candle_test.zip.
- candle_test.zip
- (3.3 KiB) Downloaded 238 times
Re: Can I paint graph with gaps for TCandleSeries?
Hi actforex,
No, I'm afraid TCandleseries' csLine mode doesn't allow null points. But you could transform your TCandleseries to be a TLineSeries. Here it is an example from the beginning:
var Series_Candle: TCandleSeries;
CandleCopy: TChartSeries;
Chart1.View3D:=false;
Series_Candle:=Chart1.AddSeries(TCandleSeries.Create(self)) as TCandleSeries;
Series_Candle.AddCandle(1, 5, 15, 4, 10);
Series_Candle.AddCandle(2, 8, 10, 1, 6);
Series_Candle.AddNull(3);
Series_Candle.AddCandle(4, 8, 14, 5, 10);
Series_Candle.AddCandle(5, 6, 10, 6, 7);
CandleCopy:=CloneChartSeries(Series_Candle);
ChangeSeriesType(CandleCopy,TLineSeries);
Series_Candle.Active:=false;
Thank you, but this is not exactly what's needed. If possible, please include this task in the development plan. This is a minor fix, but it would be very helpful for us.
So far I have managed to solve the problem by actually adding two lines into TCandleSeries.DrawValue:
if IsNull(ValueIndex) then //TF02013524
OldP.X := MaxInt; // (!)
Exit;
if FCandleStyle=csLine then // Line
if (ValueIndex<>tmpFirst) and (OldP.X <> MaxInt) then // (!)
Exit;
Hi actforex,
Thank you for the suggestion. I've added it to the wish list to be studied for inclusion asap (TV52014649).
Hi actforex,
Just wanted to let you know that I fixed TV52014649 for the next maintenance release.
You can implemented the fix in DrawValue method pending candles with CandleStyle=csLine like this:
P:=TeePoint(tmpX,YClose);
tmpFirst:=FirstDisplayedIndex;
if (ValueIndex<>tmpFirst) and (not IsNull(ValueIndex)) then
if not IsNull(ValueIndex-1) then
AssignVisiblePenColor(Self.Pen,tmpColor);
BackMode:=cbmTransparent;
if View3D then LineWithZ(OldP,P,MiddleZ)
else Line(OldP,P);
OldP:=P;
end
else if ValueIndex=tmpFirst then OldP:=P;
end
