File not found: TeeEdit.dcu
neo
Post by neo » Mon Jan 11, 2010 8:53 pm
I've recently purchase Delphi 2010. I was previoulsy using Delphi 2006 and TeeChart 7.12. I am now trying to use the TeeChart version 8 (standard) that is included with the Delphi 2010 release. I'm in the process of updating my code. Is there any reason why it cannot find the file TeeEdit. I've checked my search paths and uninstalled the old TeeChart 7. It should not be pointing to an old instance of TeeChart. I've looked at the installed packages and there is one in there: dcltee8140.bpl. Should there be another?
Thanks so much for any help.
Joe
Re: File not found: TeeEdit.dcu
Post by Yeray » Tue Jan 12, 2010 8:47 am
Hi Joe,
Please check that your IDE's library path is pointing to the correct TeeChart's lib folder. There should be your TeeEdit.dcu
