package Tee8120/Tee812 and unit CandleCh
Claus Nielsen
Post by Claus Nielsen » Thu Dec 24, 2009 1:23 pm
In the slow process of porting a D2007-delphi project to D2009, I now have all relevant third-party components installed on the Tool Palette, but I have trouble getting the TeeChart setup working correctly. When D2009 is started up, I get the message "Cannot load package Tee8120 .. it contains TeeAbout which is also contained in package Tee812". I have the TeeChart version with source code and I ran the recompile tool before opening the IDE.
- what can be done to remove this error?
Another problem haunting me is the "Error F2051 unit CandleCh was compiled with a different version of TeEngine.TChartSubGalleryProc". I tried to remove all teechart components from my forms and replace them with new ones, but delphi insists that unit CandleCh is mismatched.
- how do I handle that?
Best regards
Claus
Re: package Tee8120/Tee812 and unit CandleCh
Post by Narcís » Thu Dec 24, 2009 2:03 pm
Hi Claus,
Tee8120 is on of the packages corresponding to TeeChart v8 Standard, which is the version shipped with D2009. You should go to the packages list at Project -> Options -> Packages and disable or uninstall TeeChart 8 Standard packages.
This is a problem with your IDE or projects search paths. You should make sure that at Project -> Options -> Directories/Conditionals -> Include file search path has latest TeeChart version paths on *top* of the list, that there are no old paths listed and also do the same at Tools -> Options -> Delphi Options -> Library - Win32 -> Library path list.
Hope this helps!
Claus Nielsen
Post by Claus Nielsen » Fri Dec 25, 2009 2:07 pm
Dear Narcis,
Thank you! - this was helpful. I did have the correct search paths set and the standard TeeChart package was not listed in the components list. I looked for files containing the string 'Tee8120' and found one file in the ..\SYSTEM32 directory. I renamed it into something else, and from there on everything seemed to work well. Even the 'CandleCh' -problem disappeared! It is beyond me why D2009 was so interested in the Tee8120 file, but it is probably very difficult to make an interface that allows trouble-free plug-and-play of third party components.
Best regards
Claus
Post by Yeray » Mon Dec 28, 2009 8:49 am
Hi Claus,
Yes, delphi loads the runtime packages present at windows system folder at the IDE startup. And the TeeChart runtime packages that come with the IDEs use to end in zero (Tee*0.bpl).
