Changing order of items in the legend
TestAlways
Post by TestAlways » Fri Oct 23, 2009 11:56 pm
I need to change the order of a few items in the legend.
(I see that this is in the demo, but I do not have the current demo installed (only an older version, though I am running TChart 8.05)).
How can I move items around?
Thank you,
Ed Dressel
Re: Changing order of items in the legend
Post by Yeray » Mon Oct 26, 2009 9:03 am
Hi Ed Dressel,
In TeeChart v8 you can directly access to the legend items as shown in the demo at What's New\Welcome !\New in Legend\Items property. The only problem is that can't modify the number of items to show, only the legend style and text style. So you could personalize the text to show as follows:
var i: Integer;
  Chart1.Legend.TextStyle:=ltsValue;
  Chart1.Legend.ColumnWidthAuto:=False;
  Chart1.Legend.ColumnWidths[0]:=100;
  Chart1.Draw;
  for i := 0 to Chart1.Legend.Items.Count - 1 do
    Chart1.Legend.Item[i].Text:='Item nº ' + inttostr(i+1);
On the other hand you can also change the legend symbols like in the demo at All features\Miscellaneous\Legend\Symbol OnDraw:
procedure TLegendSymbolDraw.LegendDraw(Sender: TObject; Series:TChartSeries;
                            ValueIndex:Integer; R:TRect);
var Flag : TBitmap;
  if CheckBox1.Checked then
    Flag:=TBitmap.Create;  // create flag bitmap
    try
      Dec(R.Top,3);
      Inc(R.Bottom,3);
      // copy image from imagelist
      ImageList1.GetBitmap(ValueIndex,Flag);
      with Chart1.Canvas do
        StretchDraw(R,Flag);  // draw image to legend
        // draw border
        if Chart1.Legend.Symbol.Pen.Visible then
          Brush.Style:=bsClear;
          AssignVisiblePen(Chart1.Legend.Symbol.Pen);
          Rectangle(R,0);
    finally
      Flag.Free;  // destroy bitmap
In fact, you can use custom drawing to draw a custom rectangle, custom text and custom symbols directly over the chart. But with v9 that will be available soon, it is ready a new CustomLegendTool, that will allow much more customization:
procedure TTool_CustomLegendForm.DrawCustomLegend();
  with CustomLegendTool do
    ParentChart := Chart1;
    Grid.OnDrawCell := StringGrid1DrawCell;
    If ComboBox1.ItemIndex =0 then
      with Grid do
        ColCount := 6;
        RowCount := 3;
        RowHeights[0] := 30;
        RowHeights[1] := 30;
        RowHeights[2] := 30;
        ColWidths[1] := 70;
        Height := 95;
        Width := 390;
    end
    else begin
      with Grid do
        ColCount := 2;
        RowCount := 3;
        ColWidths[1] := 190;
        Height := 95;
        Width := 250;
        Shape.Width := 270;
procedure TTool_CustomLegendForm.StringGrid1DrawCell(Sender: TObject; ACol, ARow: Integer;
  Rect: TRect; State: TGridDrawState);
  I, J: Integer;
  Data: array[1..5,0..3] of String;
  ABitmap: TBitmap;
  FixRect, TopRect, BotRect: TRect;
  BmpWidth: Integer;
  if ComboBox1.ItemIndex=0 then
  //add some data
  for I := 1 to 5 do
    for J := 0 to 2 do
      Data[I,J] := Format('%0:3d', [round(Chart1[J].YValue[I-1])]);
  if (ACol = 0) then
    //draw the bitmap
    FixRect := Rect;
    ABitmap := TBitmap.Create;
    try
      //  ABitmap.LoadFromFile('BitmapGreen.bmp'); //use for a single image
      ImageList1.GetBitmap(ARow, ABitmap);       //different images
      BmpWidth := (Rect.Bottom - Rect.Top);
      FixRect.Right := Rect.Left + BmpWidth;
      CustomLegendTool.Grid.Canvas.StretchDraw(FixRect, ABitmap);
    finally
      ABitmap.Free;
  end
    //output the text
    TopRect := Rect;
    TopRect.Bottom := TopRect.Top+(TopRect.Bottom-TopRect.Top) div 2;
    BotRect := Rect;
    BotRect.Top := TopRect.Bottom;
    with CustomLegendTool.Grid.Canvas.Font do
      Style := [fsItalic];
      Color := clBlue;
    CustomLegendTool.Grid.Canvas.TextRect(TopRect, TopRect.Left+5, TopRect.Top+2, 'value is:');
      Style := [fsBold];
      Color := clBlue;
    CustomLegendTool.Grid.Canvas.TextRect(BotRect, BotRect.Left+10, BotRect.Top, Data[ACol,ARow]);
  end
  else begin
  //add some data text
  Data[1,0] := 'My custom Text 1';
  Data[1,1] := 'My custom Text 2';
  Data[1,2] := 'My custom Text 3';
  if (ACol = 0) then
    //draw the bitmap
    FixRect := Rect;
    try
    finally
      ABitmap.Free;
  end
    //output the text
    TopRect := Rect;
    BotRect := Rect;
    BotRect.Top := TopRect.Top ;
      Color := clBlue;
//    CustomLegendTool.Grid.Canvas.TextRect(TopRect, TopRect.Left+5, TopRect.Top+2, 'value is:');
      Style := [fsBold];
      Color := clBlue;
    CustomLegendTool.Grid.Canvas.TextRect(BotRect, BotRect.Left+10, BotRect.Top + 10, Data[ACol,ARow]);
TestAlways
Post by TestAlways » Mon Oct 26, 2009 2:21 pm
Thank you for the response. I don't see anything in your post that shows off reordering, e.g. switching item #1 with #2. Is that not possible?
Ed Dressel
Post by Yeray » Mon Oct 26, 2009 3:04 pm
Hi Ed Dressel,
In the first snipped of code I've changed all the legend items text. If you only want to change two of them you have to do something similar...
var tmp: string;
  tmp:=Chart1.Legend.Item[0].Text;
  Chart1.Legend.Item[0].Text:=Chart1.Legend.Item[1].Text;
  Chart1.Legend.Item[1].Text:=tmp;
