TeeUseMouseWheel Scroll Distance
skassan
Post by skassan » Mon Oct 19, 2009 6:12 pm
How do I control the distance that is scrolled after I set TeeUseMouseWheel to true?
Re: TeeUseMouseWheel Scroll Distance
Post by Yeray » Tue Oct 20, 2009 8:14 am
Hi skassan,
I'm afraid that this is controlled internally. Concretely, the scrolling distance is that: (Maximum-Minimum)*0.03
I'll add to the wish list the possibility to manually control this constant value.
skassan
Post by skassan » Tue Oct 20, 2009 11:57 am
When you add that functionality, you may also want to consider changing the value, or having a separate value, for when the vertical axis is in logarithmic mode. That's the reason for my original inquiry. The default behavior doesn't work too well on a logarithmic scale.
Post by Yeray » Tue Oct 20, 2009 12:06 pm
Hi skassan,
Yes, that's right. Thanks for the appreciation. I'll modify the ticket to explain that too.
