pie series - zoom larger than chart - border drawn incorrect
marder
Post by marder » Mon Oct 05, 2009 1:39 pm
Hi.
I realized that when I zoom in my pie chart so the complete pie does not fit on my chart, the pixels at the border are not drawn correctly.
Note: I am using Delphi 2010 and TeeChart V8.06
I realized that this problem did not occur on my Delphi 2009 with TeeChart V8.04!
Can you please tell me if this is a known issue and if there is a workaround?
Thanks!
Re: pie series - zoom larger than chart - border drawn incorrect
Post by Yeray » Mon Oct 05, 2009 3:12 pm
Hi marder,
Yes, I've been able to reproduce it and I've added it to the wish list to be fixed in next releases (TV52014465).
The code I used to reproduce it is the following:
uses series, TeeTools, TeeAntiAlias;
var Series1: TPieSeries;
  Series1 := TPieSeries.Create(self);
  Chart1.AddSeries(Series1);
  Series1.FillSampleValues(7);
  Chart1.Aspect.Zoom := 250;
  Chart1.Tools.Add(TAntiAliasTool.Create(self));
marder
Post by marder » Tue Oct 06, 2009 7:53 am
Dear Yeray.
Thanks for your help!
Could you tell me if this is an issue with Delphi 2010 or if this issue slipped in with the TeeChart V8.06 update?
Means: If I use Delphi 2009 with the new V8.06, would this issue still occur?
Best regards!
Post by Yeray » Tue Oct 06, 2009 11:09 am
Hi marder,
Yes, the problem is still reproducible with today's sources.
marder
Post by marder » Tue Oct 06, 2009 2:24 pm
Dear Yeray.
Thanks for your feedback, but what I meant was:
Dose this issue also occur with Delphi 2009 or only with Delphi 2010?
Thanks!
Post by Yeray » Tue Oct 06, 2009 3:32 pm
Hi marder,
Both versions come from the same sources and that doesn't seem an IDE-depending problem. So it should be reproducible with any TeeChart v8.06.
marder
Post by marder » Wed Oct 07, 2009 7:04 am
Ok, thanks!
