TChart8 and Quick Reports 5.04.2 pro Delphi 2009
kevinm_sa
Post by kevinm_sa » Fri Aug 07, 2009 7:03 am
I am having issues recompiling and installing in this environment.
I have done the teeRecompile thing and would have assumed it would do all of the work.
No joy.
If someone could give me a stepwise recipe I could probably follow that.
Thanks in advance
Kevin Murphy
Re: TChart8 and Quick Reports 5.04.2 pro Delphi 2009
Post by Yeray » Fri Aug 07, 2009 9:07 am
Hi Kevin,
Take a look at the step by step instructions from the QuickReport article here
kevinm_sa
Post by kevinm_sa » Fri Aug 07, 2009 1:33 pm
This is the error I'm trying to solve.
It now appears not to be the Teechart compile itself but something in the project ?
[DCC Fatal Error] TimeWiz.pas(8): F2051 Unit TeeEditCha was compiled with a different version of TeeStore.TSeriesDataText
Does anyone have any ideas on what to look for or what to change .
Thanks in advance
Kevin Murphy
Post by Yeray » Fri Aug 07, 2009 3:01 pm
Hi Kevin,
I've sent to your registered mail the sources I prepared for TQRChart for QuickReport 5, Teechart Pro 8 under Delphi 2009 and the compiled files generated.
I hope it helps.
