h.hasenack
- Newbie
Post
by h.hasenack » Fri Jul 24, 2009 11:30 am
In the Assignformat routine, some properties are linked rather than assigned
. This causes unexpected results when charts are destroyed, of series are changed because of unexpected links between series and charts.
I make extensive use of chart formats and format assignment in my app, and this is a nasty bug causing trouble when "cloning" a chart for e.g. reporting purposes with quickreports or reportbuilder
procedure TChartSeries.AssignFormat(Source:TChartSeries);
var t : Integer;
With TChartSeries(Source) do
<snip>
Self.FPercentFormat := FPercentFormat;
{$ifdef HH_PATCH_TC_ASSIGN}
// use assignment through properties so series will be linked onto correct axis
Self.CustomHorizAxis:= CustomHorizAxis; // 6.01
Self.HorizAxis := HorizAxis;
Self.CustomVertAxis := CustomVertAxis; // 6.01
Self.VertAxis := VertAxis;
{$else}
Self.FCustomHorizAxis:= FCustomHorizAxis; // 6.01
Self.FHorizAxis := FHorizAxis;
Self.FCustomVertAxis := FCustomVertAxis; // 6.01
Self.FVertAxis := FVertAxis;
{$endif}
Self.FRecalcOptions := FRecalcOptions;
<snip>
Regards - Hans
Post
by Yeray » Fri Jul 24, 2009 3:03 pm
Hi Hans,
Could you also send us a simple example project we can run as-is to reproduce this problem here?
h.hasenack
- Newbie
Post
by h.hasenack » Mon Jul 27, 2009 7:36 am
Hi Yeray
The "bugfix" was a remainder of a patch I had to apply with Tee4 or Tee5, and it seems to me -after some testing- me it is no longer neccessary, probably because of the call to
Self.RecalcGetAxis; { 5.01 }
some lines further on.
But I still wonder how it can be right that the series of one chart get linked to the axis of a different chart..? (I use the Assignformat to 'clone' series between series of different charts, not series within the same chart)
Post
by Narcís » Mon Jul 27, 2009 3:06 pm
Hi Hans,
Thank you very much for your collaboration!
Yes, it seems strange but IIRC some clients used that as a way of synchronizing charts or series scales using other chart's axes as custom axes.
