Marius
- Newbie
Post
by Marius » Fri Jul 17, 2009 2:07 pm
I have a candlestick chart where I add data using
.AddCandle(date, open, max, min, close)
When I display the chart I get blanks for the weekend (so basically five values and then two blanks over and over again)
How can I compress it so it that hides the weekends?
I see in the doco that you suggest using an incremental integer instead of date and then use labels but I sometimes overlay two or three other charts and do a lot of logic to figure out the scale of the X axis based on the dates... But most of the time the Candle stick chart is displayed on it's own. There isn't another way than the incremental integer is there?
Post
by Narcís » Fri Jul 17, 2009 2:17 pm
Hi Marius,
No, there's no alternative I can think of for now. Which are the exact problems you are having one using several charts together? You may get date logic retrieving label values from the series.
Marius
- Newbie
Post
by Marius » Fri Jul 17, 2009 2:22 pm
Just wanted to avoid rewriting it all....
Thanks anyway
Marius
- Newbie
Post
by Marius » Mon Jul 20, 2009 10:06 am
Narcis
Further to my earlier question....
I've now changed my code to AddCandle using a sequential number.
i := sCustom1.AddCandle(sCustom1.Count, FieldByName('OpeningValue').AsFloat, dMax, dMin, FieldByName('ClosingValue').AsFloat);
sCustom1.Labels[i] := FormatDateTime('d mmm yy', Trunc(FieldByName('IndexDate').AsDateTime));
When it comes to adjusting the X axis I use the following
chCustom.BottomAxis.Increment := 5;
chCustom.BottomAxis.MinorTickCount := 4;
chCustom.BottomAxis.LabelStyle := talText;
It displays the labels as dates but it no longer respects the Increment value. I've set it to display every 5 labels but it fits them in based on a best fit approach. If I comment out the LabelStyle line then the Increment is respected.
Any ideas?
Post
by Yeray » Mon Jul 20, 2009 11:54 am
Hi Marius,
Could you try with an increment like following?
Chart1.BottomAxis.Increment := DateTimeStep[dtOneWeek];
Marius
- Newbie
Post
by Marius » Mon Jul 20, 2009 12:46 pm
Hi Yeray
Unfortunately your suggestion does not work. DateTimeStep[dtOneWeek] simply returns 7. I need the interval to be 5 as I have removed the weekends...
Either way, even if I wanted 7 as an interval, it is still not respected...
Marius
Post
by Yeray » Mon Jul 20, 2009 2:04 pm
Hi Marius,
Yes, excuse me. I haven't understood well the problem. Setting the bottom axis labels style to show the series labels text, the increment can't be used as normally. then I recommend you to use OnGetAxisLabel event to show or hide the text. Here you have an example:
var LabelsCount: Integer;
var i: Integer;
Series1.Clear;
Chart1.View3D := false;
for i:=0 to 20 do
series1.AddCandle(i, random*100+600, random*100+800, random*100, random*100+200);
series1.Labels[i] := FormatDateTime('d mmm yy', Now-20+i);
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
if (Sender = Chart1.Axes.Bottom) then
if (LabelsCount mod 5 <> 0) then
LabelText := '';
LabelsCount := LabelsCount+1;
procedure TForm1.Chart1BeforeDrawAxes(Sender: TObject);
LabelsCount := 2;
