Save settings with charteditor
Calou
Post by Calou » Thu Jul 16, 2009 2:21 pm
By using ChartEditor at run time is there is a way to save the parameter's chart in order to have the same when the application is relauched?
Re: Save settings with charteditor
Post by Yeray » Thu Jul 16, 2009 2:33 pm
Hi Calou,
Yes, you could save the chart in a tee file and import it later. Take a look at the section TeeChart's 'Tee' template and data export/import format from the Tutorial 12 - Exporting and Importing Charts. You should find tutorials and demos at TeeChart programs group.
