compile error after upgrade v.8.05
Re: compile error after upgrade v.8.05
Post by Yeray » Tue Aug 04, 2009 8:50 am
Hi Sam,
Just sent it again.
Sam F
Post by Sam F » Wed Aug 05, 2009 1:33 am
Thank you - that works fine.
karelc
Post by karelc » Tue Aug 11, 2009 12:40 pm
Can I please get a copy of the updated files, as I am also getting this error. Is there any reason the updates can't be available on the website?
Karel
Post by Yeray » Wed Aug 12, 2009 7:18 am
Hi Karel,
I'm sorry but, as Narcis said above, this can only be sent to sourcecode customers at the present moment. We will include it with the next maintenance release.
MDA team
Post by MDA team » Thu Aug 13, 2009 11:29 am
Hi ,
We too are facing the same compiler error when we included "TeeGDIPlus.hpp" header file in our application.
Please send the modified files and procedure to use the same to solve these compiler options.
Siva Prasad.Ch
madri
Post by madri » Thu Aug 13, 2009 11:51 am
I have the same problem with version 8.05
Please, send me fixed files too.
Madri
Post by Yeray » Thu Aug 13, 2009 1:05 pm
Hi Madri,
Just sent it!
Hi Siva Prasad.Ch,
I'm sorry but, as Narcis said above, this can only be sent to sourcecode customers at the present moment. We will include it with the next maintenance release. In the meanwhile, I recommend you to use the previous v8.04. Excuse us for the inconvenience.
MDA team
Post by MDA team » Fri Aug 14, 2009 2:05 pm
Thanks a lot for your inputs.
As suggested, We tried using “TeeGDIPlus.hpp” of TeeChart Pro v8.04 to solve these compiler errors. But we could not find the same in the include path hence we could not proceed further on this issue using Pro v8.04. Please suggest how to solve this issue?
Also, we obtained source code based license for TecChart Pro v8.05 control. Please let us know whether we can obtain the required corrected file with this license.
Finally, We observed “TeeGDIPlus.hpp” is not part of TeeChart standard v8.05 control.
Siva Prasad.Ch
totte
Post by totte » Fri Aug 14, 2009 6:55 pm
I have the same problem!
Hope to get the file as soon as possible :)
Thank you,
totte
Rob Wills
Post by Rob Wills » Sun Aug 16, 2009 8:27 pm
Hi - I ordered 8.05 on Friday (full source), but am running demo now.
Have same problem.
Please send me updated header files
Rob Wills
WindMonitoring.com
Post by Yeray » Mon Aug 17, 2009 9:01 am
Hi Rob and Totte,
Rob, if I'm not wrong, you are an v7 customer, not v8 with sources.
EDIT: The sales department told me that your v8 source code command has just been processed so I can send you the files.
Totte, if I'm not wrong, you are a v8 customer without sources.
Please, note that this is a bugfix for 8.05 and it's available only for source code customers because the patch includes part of the source.
RWills
Post by RWills » Tue Aug 18, 2009 10:22 pm
No files received yet - please send asap.
License received and source code V8.05 is downloaded OK.
RWills
Post by Yeray » Wed Aug 19, 2009 6:45 am
Hi Rob,
I've re-sent the files to your forums registered mail. Could you please check if you have any filter active in your mail server?
Beto
Re: Compile error after upgrade v.8.05
Post by Beto » Wed Aug 26, 2009 3:08 pm
I got the same errors after upgrading to version 8.05, please, send me the fixed files too.
Thanks a lot.
[BCC32 Error] Gdipapi.hpp(71): E2257 , expected
[BCC32 Error] Gdipapi.hpp(77): E2257 , expected
[BCC32 Error] Gdipapi.hpp(79): E2257 , expected
[BCC32 Error] Gdipapi.hpp(83): E2257 , expected
[BCC32 Error] Gdipapi.hpp(85): E2257 , expected
[BCC32 Error] Gdipapi.hpp(87): E2257 , expected
[BCC32 Error] Gdipapi.hpp(89): E2257 , expected
[BCC32 Error] Gdipapi.hpp(93): E2257 , expected
[BCC32 Error] Gdipapi.hpp(95): E2257 , expected
[BCC32 Error] Gdipapi.hpp(99): E2257 , expected
[BCC32 Error] Gdipapi.hpp(101): E2257 , expected
[BCC32 Error] Gdipapi.hpp(109): E2257 , expected
[BCC32 Error] Gdipapi.hpp(111): E2257 , expected
[BCC32 Error] Gdipapi.hpp(115): E2257 , expected
[BCC32 Error] Gdipapi.hpp(121): E2257 , expected
[BCC32 Error] Gdipapi.hpp(123): E2257 , expected
[BCC32 Error] Gdipapi.hpp(127): E2257 , expected
[BCC32 Error] Gdipapi.hpp(129): E2257 , expected
[BCC32 Error] Gdipapi.hpp(133): E2257 , expected
[BCC32 Error] Gdipapi.hpp(137): E2257 , expected
[BCC32 Error] Gdipapi.hpp(141): E2257 , expected
[BCC32 Error] Gdipapi.hpp(267): E2257 , expected
[BCC32 Error] Gdipapi.hpp(269): E2257 , expected
[BCC32 Error] Gdipapi.hpp(273): E2257 , expected
[BCC32 Error] Gdipapi.hpp(283): E2257 , expected
[BCC32 Error] Gdipapi.hpp(287): E2257 , expected
[BCC32 Error] Gdipapi.hpp(289): E2257 , expected
[BCC32 Error] Gdipapi.hpp(301): E2257 , expected
[BCC32 Error] Gdipapi.hpp(305): E2257 , expected
[BCC32 Error] Gdipapi.hpp(309): E2257 , expected
[BCC32 Error] Gdipapi.hpp(381): E2257 , expected
[BCC32 Error] Gdipapi.hpp(389): E2257 , expected
[BCC32 Error] Gdipapi.hpp(395): E2257 , expected
[BCC32 Error] Gdipapi.hpp(397): E2257 , expected
[BCC32 Error] Gdipapi.hpp(401): E2257 , expected
[BCC32 Error] Gdipapi.hpp(405): E2257 , expected
[BCC32 Error] Gdipapi.hpp(409): E2257 , expected
[BCC32 Error] Gdipapi.hpp(413): E2257 , expected
[BCC32 Error] Gdipapi.hpp(415): E2257 , expected
[BCC32 Error] Gdipapi.hpp(417): E2257 , expected
[BCC32 Error] Gdipapi.hpp(467): E2257 , expected
[BCC32 Error] Gdipapi.hpp(469): E2257 , expected
[BCC32 Error] Gdipapi.hpp(473): E2257 , expected
[BCC32 Error] Gdipapi.hpp(485): E2257 , expected
[BCC32 Error] Gdipobj.hpp(47): E2238 Multiple declaration for '_fastcall TGPRegion::TGPRegion(void *)'
[BCC32 Error] Gdipobj.hpp(39): E2344 Earlier declaration of '_fastcall TGPRegion::TGPRegion(void *)'
[BCC32 Error] Gdipobj.hpp(243): E2303 Type name expected
[BCC32 Error] Gdipobj.hpp(290): E2238 Multiple declaration for '_fastcall TGPBitmap::TGPBitmap(void *)'
[BCC32 Error] Gdipobj.hpp(269): E2344 Earlier declaration of '_fastcall TGPBitmap::TGPBitmap(void *)'
[BCC32 Error] Gdipobj.hpp(866): E2238 Multiple declaration for '_fastcall TGPGraphics::TGPGraphics(void *)'
[BCC32 Error] Gdipobj.hpp(866): E2228 Too many error or warning messages
Post by Narcís » Wed Aug 26, 2009 3:13 pm
Just sent you the file.
