X Coordinate from Bar
Post by Narcís » Wed Nov 21, 2007 4:01 pm
Hi AchatSolutions,
I have uploaded your code in a sample project by using version 5.02 with filename 'AchatSolutions_LineNotCentered_Sample.zip'.
I haven't found this project. Where did you send it?
AchatSolutions
Post by AchatSolutions » Wed Dec 05, 2007 8:07 am
I m so sorry.. i have not seen this post..
I have uploaded it one more time.. result:
Received AchatSolutions_LineNotCentered_Sample.rar Content Type application/octet-stream Length 243664
So i have tried to write your sample code in my application..
I add my bars with 'BarSeries1.AddXY'
And i am using this code to find out the x value for the efficiency line:
      lPosValue := Chart.Series[lSeriesIx].CalcXPos(aLineIx);
      lXValue := Chart.BottomAxis.CalcPosPoint(lPosValue);
But lPosValue has always the same value.. so 'CalcPosPoint' too.
lSeriesIx is the BarSeries.
aLineIx is the actual "numpoint'
So the function 'CalcXPos' dont care whats lSeriesIx contains. If there is 0 or 1 its always the same value for lPosValue.
Are there any special properties or codes to make this work?
In the sample application it works very fine. But not in my main application. And i cannot make a demo thats reproduce this problem.
Hope you can help me.
Thanks!
Edit (5. December, 10.30 am):
I am creating all bar series (for every year one) and the efficiency line dynamcly at runtime! Only the chart is build up at design time.
Edit (6 December, 10:25 am):
OK now im using 'Marks.Position' instead of CalcXPos:
lPosValue := aMasterSeries.Marks.Positions.Position[0].ArrowFrom.X;
This works. The result is correct but after this function i must call
But this function always returns 1.
Are there any Ideas?
Post by Yeray » Thu Dec 13, 2007 9:57 am
Hi AchatSolutions,
Using OnAfterDraw event to calculate the BarWidth you can use it to repopulate the efficiency line according to the actual Bottom Axis scale. So, you'll be able to have a good efficiency line even zooming and unzooming.
const aboveValue = 100;
var i:integer;
    BarWidth: double;
  BarWidth := Chart1.BottomAxis.CalcPosPoint(Series1.BarBounds.Right) -
                  Chart1.BottomAxis.CalcPosPoint(Series1.BarBounds.Left);
  Series6.clear;
  for i:= 0 to numpoints-1 do
    Series6.AddXY(i+1-(BarWidth*2), Series1.YValue[i]+aboveValue);
    Series6.AddXY(i+1-BarWidth, Series2.YValue[i]+aboveValue);
    Series6.AddXY(i+1, Series3.YValue[i]+aboveValue);
    Series6.AddXY(i+1+BarWidth, Series4.YValue[i]+aboveValue);
    Series6.AddXY(i+1+(BarWidth*2), Series5.YValue[i]+aboveValue);
    Series6.AddNullXY(i+1+(BarWidth*3), aboveValue ,'');
  Chart1.Refresh;
