Access denied with TeeExport
Bert Kreisel
Re: Access denied with TeeExport
Post by Bert Kreisel » Fri Jun 29, 2012 11:40 am
finally TTeeExportFormBase.GetTempFolder is working now. I think you have solved the 2 years old Problem. Congrats!
Best Regards
Bert Kreisel
Post by Yeray » Fri Jun 29, 2012 1:35 pm
Hi Bert,
Great! But I'm sorry for such a trivial solution to have taken so long...
Since earlier in this thread you assumed the TV52014935 bug was related to the "Access denied" bug discussed here, I'd like to confirm if TV52014935 has been fixed with it. Could you reproduce the freeze problem before applying the fix, or just the "Access denied"? And after applying the fix?
Bert Kreisel
Post by Bert Kreisel » Fri Jun 29, 2012 1:49 pm
before applying the fix I got a MessageBox compaining c:\TeeChart.bmp Access denied. After applying the fix it works in the IDE and in my program.
Best Regards
Bert Kreisel
Post by Yeray » Fri Jun 29, 2012 3:30 pm
Hi Bert,
Right. That's what I understood.
However, I'm not sure if this has also fixed the the TV52014935 bug as well.
