Is there a way to get the series marks above the items they are marking? Or to put the axis labels inside the graph itself?
Essentially what I want to do is get a graph that looks like:
| Widgets
| Wotsits
| Doobreys
| Thingamebobs
Try as I might with Teechart Pro 6, I can't get it to work. If it can't be done, this is a must-do for version 7 as so many other charts I see can do this. I must be missing something!
Matthew
Series marks outside of bar
Hi Mathew,
>Is there a way to get the series marks above the items they are >marking? Or to put the axis labels inside the graph itself?
Yes, you can customize the Marks positions using something like the following code :
Also, I think there's one example of this in the TeeChart Pro Demo Features Project.
with Series1.Marks.Positions[0] do
Custom:=True;
LeftTop.X:=100;
LeftTop.Y:=150;
Pep Jorge
http://support.steema.com
