Formatting Help with a Circular Gauge...
JNuzzi
Post by JNuzzi » Mon Jun 09, 2025 4:27 pm
Hello All,
I have been struggling like heck to get the Gauge to look like I want. Currently, it looks like this:
Screenshot 2025-06-09 122458.png (6.5 KiB) Viewed 924 times
I would like the labels offset more from the frame and centered on their tick. What setting am I missing (I tried about a million things), or maybe it is not possible?
John
JNuzzi
Re: Formatting Help with a Circular Gauge...
Post by JNuzzi » Mon Jun 09, 2025 6:51 pm
Activating the GDI+ has moved the label off of the frame, so that's good. I still can figure out how to center the labels on their tick, though.
Screenshot 2025-06-09 144323.png (9.99 KiB) Viewed 900 times
I tried using OpenGL, but it seems to struggle with the Circular Gauge...at least as I have it configured:
Screenshot 2025-06-09 144951.png (12.7 KiB) Viewed 900 times
I really wish I knew what Steema's fascination with default gradients everywhere is. It's such a PITA to remove it all.
NUZ
Post by Yeray » Wed Jun 11, 2025 10:16 am
I'm afraid the alignment of the labels in the CircularGauge is an old issue in the list: #833.
We'll take a look at it.
Well, it's a component born when the tends were different... yes gradients everywhere with saturated colors.
This usually helps to clean the majority, not for the CircularGauge I'm afraid:
uses TeeThemes;
    ApplyChartTheme(TLookoutTheme, Chart1);
JNuzzi
Post by JNuzzi » Wed Jun 11, 2025 11:02 am
Thank you for the reply, Yerah. But, wow, first reported 11 years ago. I probably don't have much hope of seeing it resolved by the time I finish this project? Is there a way to "owner draw" it, perhaps? I looked at a few of the events associated with the chart and the series, but did not find anything that would provide the insertion point or position (angle) on the frame to get the angle right.
Thanks again,
NUZ
Post by Yeray » Thu Jun 12, 2025 9:10 am
I've been able to fix that old bug #833.
I've also added a related fix/feature. Now the labels consider the Axis.Texts.MarginToAxis when being drawn.
I believe you don't have the TeeChart sources so I can't send you the diff.
However, if you can tell me what TeeChart and RAD versions you are using, I can try to prepare a patch for you.
Here is my example:
uses Chart, TeEngine, TeeCircularGauge;
var Chart1: TChart;
  Chart1:=TChart.Create(Self);
  with Chart1 do
    Parent:=Self;
    Align:=alClient;
    Color:=clWhite;
    Gradient.Visible:=False;
    Walls.Back.Color:=clWhite;
    Legend.Hide;
    View3D:=False;
    with TCircularGauge(AddSeries(TCircularGauge)) do
      Frame.Hide;
      EndPoint.Hide;
      Center.Hide;
      Hand.Shadow.Hide;
      Hand.Gradient.Visible:=False;
      Hand.Color:=$701919;
      Hand.Distance:=0;
      Hand.HorizSize:=10;
      Hand.Style:=psTriangle;
      Hand.Offset:=100;
      Axis.Texts.MarginToAxis:=30;
      for var i:=0 to Ranges.Count-1 do
        Ranges[i].Format.Position:=0;
        Ranges[i].Format.Size:=25;
        Ranges[i].Format.Gradient.Visible:=False;
        Ranges[i].Format.Spiralled:=False;
      Ranges[0].EndValue:=12;
      Ranges[1].StartValue:=12;
      Ranges[1].EndValue:=20;
      Ranges[0].Format.Color:=$00ffff;
      Ranges[1].Format.Color:=$f0caa6;
      LabelsInside:=False;
      Axis.LabelsFont.Color:=clBlack;
      Axis.LabelsFont.Size:=12;
      Maximum:=20;
      Axis.Increment:=4;
      ValueFormat:='#,##0.0';
      Value:=19;
    Title.CustomPosition:=True;
    Title.Text.Text:='19.0';
    Title.Font.Size:=12;
    Title.Font.Style:=[fsBold];
    Title.Font.Color:=clBlack;
    Draw;
    Title.Left:=(Self.Width div 2) - (Title.Width div 2) - 8;
    Title.Top:=TCircularGauge(Chart1[0]).CircleYCenter - Title.Height - 10;
JNuzzi
Post by JNuzzi » Thu Jun 12, 2025 12:06 pm
Oh, that is awesome. Thank you. I am using RADStudio C++ 12 Version 29.0.55362.2017, and TChart (it looks like) 2023.39. I'm not sure where to find the actual installed version number, but I got that from the most recent TeeChart installation package in my downloads folder. I just went to the customer portal to see what my downloads there are, but scanning my emails, I found multiple customer numbers. However, whatever I am using, I am most definitely willing to upgrade to the newest version today. I will look into that since this project has become so reliant on them. I may even go with the source code version...I'll see what the money people say.
NUZ
Edit: I upgraded just now to the non-source pro version. I have not installed it yet as the order is still processing.
Post by Yeray » Thu Jun 12, 2025 12:52 pm
Then I guess it will be TeeChart v2025.44.
Can you also please tell me what target platform are you using? I may need to send you all the units for the target platforms you use to avoid "the unit xxx was compiled with a different version of yyy" errors.
Note you can know what TeeChart version you are using at design time opening the about box from a TChart in a form.
And you can know what TeeChart version is used to build with:
uses TeeConst;
  Caption:=TeeMsg_Version;
JNuzzi
Post by JNuzzi » Thu Jun 12, 2025 1:38 pm
Windows 32-bit, 64-bit, 64-bit (Modern) Debug and Release...so, i guess, all of them :-)
JNuzzi
Post by JNuzzi » Thu Jun 12, 2025 1:52 pm
To make it easier, I am just going to upgrade to the source version. Trying to get that straightened out now.
JNuzzi
Post by JNuzzi » Thu Jun 12, 2025 2:56 pm
OK, new license achieved. If you want to just do the source diff, that should work.
Thank you, again...
NUZ
Post by Yeray » Fri Jun 13, 2025 7:10 am
Oh, that's good news!
I've split the diff in two parts so you can apply them independently if you want:
- Fix for #833: CircularGauge labels misaligned
--- a/TeeCircularGauge.pas
+++ b/TeeCircularGauge.pas
@@ -789,6 +789,15 @@ begin
     TTeePanelAccess(ParentChart).TryAssignFont(Axis.Texts.Font);
+    case Axis.LabelsFormat.TextAlignment of
+      taLeftJustify:
+        ParentChart.Canvas.TextAlign:=TA_LEFT;
+      taCenter:
+        ParentChart.Canvas.TextAlign:=TA_CENTER;
+      else
+        ParentChart.Canvas.TextAlign:=TA_RIGHT;
+    end;
     if tmpStep=0 then
       // Calculate best label increment based on radius, font size and TotalAngle:
- Feat: use MarginToAxis in CircularGauge
@@ -724,6 +724,7 @@ var
   tmpXRadius,
   tmpYRadius,
   tmpW,
+  tmpMargin,
   t: Integer;
   P3Plus,
@@ -823,6 +824,8 @@ begin
          tmpFontH:=0;
+      tmpMargin:=Round(tmpFontH*Axis.Texts.MarginToAxis*0.01);
       if (IRange <> 0) and (tmpStep <> 0) then
         tmpValue := 0;
@@ -864,11 +864,13 @@ begin
               tmpAngle2 := CalcAngleFromLength(P4,0)*0.5;
               if LabelsInside then
-                 P3 := CalcPoint(tmp - tmpAngle2, ICenter, tmpXRad -
-                                (tmpFontH * 0.25), tmpYRad - (tmpFontH * 0.25))
+                 P3 := CalcPoint(tmp - tmpAngle2, ICenter,
+                                 tmpXRad - (tmpFontH * 0.25) - tmpMargin,
+                                 tmpYRad - (tmpFontH * 0.25) - tmpMargin)
-                                 tmpXRadius + tmpFontH, tmpYRadius + tmpFontH);
+                                 tmpXRadius + tmpFontH + tmpMargin,
+                                 tmpYRadius + tmpFontH + tmpMargin);
               {$IFDEF FMX}
               TCanvasAccess(ParentChart.Canvas).IUseTextCenter:=True;
@@ -885,7 +888,7 @@ begin
-                P3:=CalcPoint(tmp, ICenter, tmpXRad - tmpHalf, tmpYRad - tmpHalf);
+                P3:=CalcPoint(tmp, ICenter, tmpXRad - tmpHalf - tmpMargin, tmpYRad - tmpHalf - tmpMargin);
                 tmpAngle2 := tmpAngle - 90;
@@ -898,7 +901,7 @@ begin
               end
-                P3:=CalcPoint(tmp, ICenter, tmpXRadius + tmpFontH, tmpYRadius + tmpHalf);
+                P3:=CalcPoint(tmp, ICenter, tmpXRadius + tmpFontH + tmpMargin, tmpYRadius + tmpHalf + tmpMargin);
               {$IFDEF FMX}
               P3.Y:=P3.Y-tmpHalf;
Don't forget to rebuild the sources (with TeeRecompile) after applying the changes.
And don't hesitate to let us know if you find any problem with this!
