Move/Rotate Left-Axis Caption above Axis
Ed Dressel
Post by Ed Dressel » Fri Jun 06, 2025 8:36 pm
Move left-axis label to the top of the axis.
My graphic designer suggested that the left axis label be moved & rotated to the top of the axis, as seen in the images below. Is this possibe?
(image URL is www.tbinc.com/Misc/TChartLeftAxis.jpg --I don't know why but I cannot get it to display in the preview).
Ed Dressel
Ed Dressel
Re: Move/Rotate Left-Axis Caption above Axis
Post by Ed Dressel » Fri Jun 06, 2025 8:45 pm
I should have mentioned--I did try using the top axis caption, but I cannot find how to remove the space between the bottom of the caption and the top of the chart.
Post by Yeray » Wed Jun 11, 2025 6:56 am
Have you tried with the main title? It seems to give the result you'd expect:
  with Chart1 do
    Title.Text.Text := 'Monthly income';
    Title.Font.Color := Axes.Left.LabelsFont.Color;
    Title.Font.Size := 15;
    Title.Alignment := taLeftJustify;
left title.png (11.93 KiB) Viewed 4645 times
I see a "mixed content" warning in the console. I guess your server isn't using SSL and non-SSL content (http://) can't be fetched from SSL connections (https://) due to security restrictions in modern browsers.
Ed Dressel
Post by Ed Dressel » Thu Jun 12, 2025 3:09 pm
Thank you on both issues--I found another way to upload images (even quicker using a product named SnagIt. I didn't realize it had these features).
Post by Yeray » Fri Jun 13, 2025 7:15 am
I use ShareX for screen capturing, but I suppose it’s a matter of personal preference.
Also note this forum supports attaching images.
