In the attached demo, I have a TChart that has bars, some with negative values.
The image is visible here: https://app.screencast.com/iyBZFNk6yvUsB
I have two items I need help with.
1) For the first red bar with a negative value, there is no margin between the red and the axis--how do I create a margin between the red bar and the line at the bottom?
2) For the left axis, I want the zero value line to be the darker/heavier line, and the other lines to be lighter.
How can I achieve this?
Ed Dressel
Charts with Bars with Negative values
- Bars Negative Values.zip
- (6.95 KiB) Downloaded 2938 times
Re: Charts with Bars with Negative values
Hello Ed,
The problem is that, moving the bottom axis to the middle of the chart, then the labels are drawn behind the bars, and you probably don't want that.
There's a
Then, the trick is to play with
You can add some offset to the left axis:Ed Dressel wrote: ↑Thu Dec 19, 2024 7:36 pm1) For the first red bar with a negative value, there is no margin between the red and the axis--how do I create a margin between the red bar and the line at the bottom?
Chart1.Axes.Left.MaximumOffset:=10;
Chart1.Axes.Left.MinimumOffset:=10;
You can move the Bottom with theEd Dressel wrote: ↑Thu Dec 19, 2024 7:36 pm2) For the left axis, I want the zero value line to be the darker/heavier line, and the other lines to be lighter.
PositionPercent
property calculating the position of the 0 value in pixels as follows:Code: Select all
Chart1.Axes.Bottom.PositionUnits:=muPixels;
Chart1.OnBeforeDrawAxes:=AxesBeforeDraw;
Chart1.Draw;
procedure TForm1.AxesBeforeDraw(Sender: TObject);
Chart1.Axes.Bottom.PositionPercent:=Chart1.ChartRect.Bottom - Chart1.Axes.Left.CalcPosValue(0);
There's a
Axes.Behind
property you can set to False
, but then the left axis grid will also be drawn on top of the bars, which you probably don't want.Then, the trick is to play with
OnBeforeDrawChart
and AfterDrawValues
events to disable and enable those properties. Ie:Code: Select all
Chart1.OnBeforeDrawChart:=ChartBeforeDraw;
Series1.AfterDrawValues:=SeriesAfterDraw;
procedure TForm1.ChartBeforeDraw(Sender: TObject);
Chart1.Axes.Behind:=True;
Chart1.Axes.Bottom.Texts.Font.Color:=clNone;
Chart1.Axes.Left.Grid.Visible:=True;
procedure TForm1.SeriesAfterDraw(Sender: TObject);
Chart1.Axes.Behind:=False;
Chart1.Axes.Bottom.Texts.Font.Color:=clBlack;
Chart1.Axes.Left.Grid.Visible:=False;
Thank you. That works well--but is there any way to move the series labels (e.g. "2 Years Before") below the chart, rather than overwriting the series)?
Hello Ed,
That's easier. You only need to hide the Bottom axis pen and add aEd Dressel wrote: ↑Fri Dec 20, 2024 3:45 pmis there any way to move the series labels (e.g. "2 Years Before") below the chart, rather than overwriting the series)?
TColorLineTool
.Code: Select all
uses VCLTee.TeeTools;
var ColorLine1: TColorLineTool;
Chart1.Axes.Bottom.Axis.Hide;
ColorLine1:=TColorLineTool(Chart1.Tools.Add(TColorLineTool));
ColorLine1.AllowDrag:=False;
ColorLine1.DragRepaint:=True;
ColorLine1.Axis:=Chart1.Axes.Left;
ColorLine1.Value:=0;
