Surface chart grows in size when starting to rotate
I have a VCLTee.TeeSurfa 3D surface chart using the Athens version of Delphi and the latest teeChart version. I define my chart to be about half the size of the containing panel, and with the Rotate tool. When I first display the chart at runtime, it is the designed size. However, as soon as I start dragging it to rotate it, it jumps to about a 50% larger size in all 3 dimensions. How do I prevent this resizing?
Re: Surface chart grows in size when starting to rotate
The
Sometimes, setting your starting view with
The
TRotationTool
modifies the Rotation
and the Elevation
properties, but to do so, it also sets Orthogonal
property to False
.Sometimes, setting your starting view with
Orthogonal:=False
avoids that jump when using the TRotationTool
.If you still find problems with it, please arrange a simple example project we can run as-is to reproduce the problem here.
Thank you very much. That worked.
