Installation of TeeChart VCL/FMX version 2021 Build 2021.33.210915
ZLukacs
Post by ZLukacs » Mon Jan 03, 2022 11:46 am
I tried to install the subject version under -Embarcadero® RAD Studio 10.4 Version 27.0.40680.4203 (Update 2). After installation I found that important units were missing (see attached files).
Please note that I did not install the free version of TeeChart, distributed with RAD, because earlier, when I did, the new elements did not appear in the Palette.
Please help.
TeeChart Installation Problem Screenshot2.png (4.66 KiB) Viewed 9546 times
TeeChart Installation Problem Screenshot1.png (8.35 KiB) Viewed 9546 times
Re: Installation of TeeChart VCL/FMX version 2021 Build 2021.33.210915
Post by Yeray » Mon Jan 03, 2022 5:01 pm
Try adding VCLTee to the "unit scope names".
ZLukacs
Post by ZLukacs » Wed Jan 05, 2022 8:17 pm
Screenshots with errors, after trying to compile, BEFORE and AFTER adding "VCLTree."
Please advise further actions in order to avoid new obstacles.
Error message after adding "VCL.Tree" to the unit names.
TeeChart Installation Problem Screenshot4.png (44.55 KiB) Viewed 9528 times
Before adding "VCL.Tree"
TeeChart Installation Problem Screenshot3.png (10.05 KiB) Viewed 9528 times
Post by Yeray » Wed Jan 05, 2022 8:31 pm
You don't have to modify the contents of any unit. Instead, you need to add VCLTee at the "Tools/Options, Language, Delphi Options, Library, Unit scope names" menu.
ZLukacs
Post by ZLukacs » Thu Jan 06, 2022 9:44 pm
Thanx, works!
Zoltan
