Winapi DrawText on chart no longer use canvas settings
athely
Post by athely » Tue Dec 19, 2017 1:20 pm
Since i've upgrade my RAD from D2009 to XE10.1 and Teechart from 8.08 to 2017.10, DrawText function (from winapi unit) no longer use canvas settings as font color, size, etc...
Same function on TImage canvas works fine!
Please find attached small project highlighting problem.
I use Delphi XE10.1 and TeeChart Pro VCL FMX Source Code 2017.20.
Thanks for your help
Anthony
TestTChartLDrawText - XE10.1.zip
(25.96 KiB) Downloaded 1513 times
Re: Winapi DrawText on chart no longer use canvas settings
Post by Yeray » Wed Dec 20, 2017 2:18 pm
Hello Anthony,
It works as always if you switch back from GDIPlus to GDI:
uses TeCanvas;
  Chart.Canvas:=TTeeCanvas3D.Create;
athely
Post by athely » Thu Dec 21, 2017 3:07 pm
Ok thank, it works finein GDI mode!
Is it planned to fix problem in GDIPlus?
Anthony
Post by Marc » Thu Dec 28, 2017 9:48 am
Hello Anthony,
We don't have this listed to modify for GDI+. There is the alternative approach using TeeChart's own TextOut.
eg.
Chart.Canvas.Font.Color := clred;
  Chart.Canvas.Font.Size := 15;
  Chart.Canvas.TextOut(r.Left,r.Top,str);
You'd need to add some code to divide up your lines at the spaces.
odaumas
Post by odaumas » Wed May 20, 2020 1:03 pm
Hello anyone,
Back to this problem.
The use of DrawText being much more powerful than the use of TextOut, isn't the correction of this regression planned yet ?
Post by Marc » Tue Jun 23, 2020 10:30 am
When using GDI+, TeeChart uses the GDI+ DrawString method internally.
