How to place a 'point' on a horizontal bar graph.
VideoTrack
Post by VideoTrack » Tue Oct 09, 2018 11:08 am
I want to draw a horizontal bar graph series and draw one of more points at some location over the horizontal bar.
The bars work fine until I want to add the points, and then only every second bar is displayed.
How can I show TPoints and also display every horizontal bar?
var
HSeries : array of THorizBarSeries;
PSeries : array of TPointSeries;
procedure TForm4.Button1Click(Sender: TObject);
var
Rnd : Integer;
i : Integer;
j : Integer;
MyColour : TColor;
SetLength(HSeries, 0);
SetLength(PSeries, 0);
Chart1.RemoveAllSeries;
Chart1.LeftAxis.Items.Clear;
series1.StackGroup := 0;
Chart1.LeftAxis.Items.Count := 0;
Chart1.Pages.MaxPointsPerPage := 16;
for i := 0 to 150 do
  SetLength(HSeries, i+1);
  SetLength(PSeries, i+1);
  HSeries[i] := THorizBarSeries.Create(Chart1);
  Hseries[i].MultiBar := mbNone;
  HSeries[i].StackGroup := i;
  HSeries[i].Marks.Visible := False;
  HSeries[i].BarWidthPercent := 90;//100; //95;
  Chart1.AddSeries(HSeries[i]);
  MyColour := clGreen;
  Rnd := Random(45);
  Rnd := 45 + Rnd;
  HSeries[i].AddX(Rnd, '', MyColour);
  Hseries[i].MultiBar := mbSelfStack;
  Chart1.LeftAxis.Items.Add(i);  {i+1}
  Chart1.LeftAxis.Items.Item[i].Text:= IntToStr(i+1)+' Chk'+IntToStr(Rnd);
  {draw the yellow and red}
  for j := 2 to 3 do
    if j = 2 then myColour := clYellow
    else MyColour := clRed;
    HSeries[i].AddX(j*2, '', MyColour);
  {draw the point over the top of the horizontal bar graph}
  Rnd := Random(25);
  Rnd := 20 + Rnd;
  PSeries[i] := TPointSeries.Create(Chart1); // (self);
  PSeries[i].Marks.Visible := False;
  PSeries[i].Pointer.Style := psTriangle;
  PSeries[i].AddXY(Rnd, i, '', clYellow);
  Chart1.AddSeries(PSeries[i]);
  end; {for i}
HorizBar series shows every bar when not adding the TPoint
Drawing the HorizBarSeries with adding a TPoint only draws every 2nd bar which is incorrect
VideoTrack
Re: How to place a 'point' on a horizontal bar graph. [Solved]
Post by VideoTrack » Fri Oct 12, 2018 12:09 am
Resolved by adding the Point series separately:
{______________________________________________________________________________}
var
Rnd : Integer;
i : Integer;
j : Integer;
MyColour : TColor;
{attempt to add a data set to the bar chart}
SetLength(HSeries, 150);
  Rnd := Random(45);
  Rnd := 45 + Rnd;
  Chart1.LeftAxis.Items.Item[i].Text:= IntToStr(151-i)+' GT:'+IntToStr(Rnd);
  for j := 2 to 3 do
  end; {for i}
ScrllBarChange(Chart1);
procedure TForm4.Button2Click(Sender: TObject);
var
Rnd : Integer;
i : Integer;
SetLength(PSeries, 150);
  Rnd := Random(25);
  Rnd := 20 + Rnd;
  PSeries[i].Pointer.Size := 3;
Add the Point series separately, not in the same loop that adds Horizontal Bar series.
Post by Yeray » Mon Oct 15, 2018 6:48 am
I'm glad to hear you found how to solve it!
