IntraWeb + VCL
IntraWeb + VCL
I would like to use a TDBChart variant with IntraWeb (Datasource: TADODataSet component). However, the appropriate Steema / Intraweb components are missing.
My environment:
- Embarcadero C++ Builder 10.1 Berlin Update 2 Ent
- IntraWeb version: 14.2.6 (IntraWeb Bundled Edition for RAD Studio XE3-10.2 Ent/Arch), recommended, free update of Atozed Software
- Win 7 SP1 Ent
https://www.steema.com/downloads/vcl:
... Additional downloads, Integration for IntraWeb
Old Version: TeeChart Standard 2013 for IntraWeb 14.0 in Delphi XE4 (September 09, 2013)
I think the design time / run time packages need it (*.bpl) for C++Builder.
Can you help?
Regards, Ralf
My environment:
- Win 7 SP1 Ent
Can you help?
Regards, Ralf
Re: IntraWeb + VCL
I've just added to the list the zip containing the sources for the integration of TeeChart into Intraweb 14 for RAD Studio 10.1 Berlin.
Could you please give it a try?
Re: IntraWeb + VCL
Hello Yeray,
unfortunately there are problems. I am using the latest update recommended by Atozed Software on IntraWeb to 14.2.x (https://www.atozed.com/category/iw/iw-release/), the original Bundled version 14.0 had to be uninstalled.
Does the version supplied by Embarcadero have to be used?
Target _PasCoreCompile:
c:\program files (x86)\embarcadero\studio\18.0\bin\dcc32.exe -$O- -$W+ --no-config -B -Q -TX.bpl -
C:\Users\[user]\Documents\Embarcadero\Studio\Projekte\TeeChart_2017_for_IntraWeb_14.0_and_RADStudio_XE10.1_Berlin_Std\IW140TeeChart9_240.dpk(39,10): error F2202: E2202 Package 'Intraweb' wird benötigt, konnte aber nicht gefunden werden
Done building target "_PasCoreCompile" in project "IW140TeeChart9_240.dproj" -- FAILED.
Done building project "IW140TeeChart9_240.dproj" -- FAILED.
Ralf
Ralf
Re: IntraWeb + VCL
I only had to modify an entry in the requires section in the IW140TeeChart9_240.dpk file, from "Tee" to "Tee924". If you use the TeeChart Standard/Lite shipped with the IDE, the packages should work without this change.
What TeeChart version do you have installed?
I've just installed v14.2.7 and the packages seem to compile fine with TeeChart Pro v2017.23 installed.Ralf1603 wrote:I am using the latest update recommended by Atozed Software on IntraWeb to 14.2.x (https://www.atozed.com/category/iw/iw-release/), the original Bundled version 14.0 had to be uninstalled.
Re: IntraWeb + VCL
Hello Yeray,
I've installed IntraWeb v14.2.7 and now TeeChart Pro v2017.23 installed, modify "IW140TeeChart9_240.dpk".
Loaded in IDE "TeeChart Std 2017 for Intraweb 14 and RADStudio XE 10.1 Berlin.groupproj"
[dcc32 Fataler Fehler] IW140TeeChart9_240.dpk(39): E2202 Package 'Intraweb' wird benötigt, konnte aber nicht gefunden werden
requires
rtl,
vcl,
vclx,
inet,
vclimg,
Tee924,
Intraweb;
[dcc32 Fataler Fehler] DCLIW140TeeChart9_240.dpk(35): E2202 Package 'Tee' wird benötigt, konnte aber nicht gefunden werden
requires
rtl,
designide,
IW140TeeChart9_240;
Thanks for the support.
Best regards,
Ralf
requires
rtl,
vcl,
vclx,
inet,
vclimg,
Tee924,
Intraweb;
requires
rtl,
designide,
IW140TeeChart9_240;
Best regards,
Ralf
Re: IntraWeb + VCL
Hello Ralf,
It seems the "Intraweb" and "Tee" packages can't be found. Please try to modify the requires list matching the packages (bpls) you have installed.
In IW140TeeChart9_240.dpk, try replacing "Intraweb" by "Intraweb_14_D10_1"
Re: IntraWeb + VCL
Hello Yeray,
Thank you very much. I changed the file.
Now I get the error message when compiling the project file. There is no "dcr" file in the "TeeChart_2017_for_IntraWeb_14.0_and_RADStudio_XE10.1_Berlin_Std" archive, can you use the "dcr" file from "Steema TeeChart Pro VCL FMX 2017.23"?
Abhängigkeiten des Projekts werden überprüft...
Erzeugen von DCLIW140TeeChart9_240.dproj (Debug, Win32)
brcc32 Befehlszeile für "DCLIW140TeeChart9_240.vrc" ...
dcc32 Befehlszeile für "DCLIW140TeeChart9_240.dpk" ...
[dcc32 Fehler] E1026 Datei nicht gefunden: 'IWCompTeeChart.dcr'
Misslungen
Verstrichene Zeit: 00:00:01.0
C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX 2017.23\Examples\VCL for the Web
IWCompTeeChart.pas 3,06 KB (3.138 Bytes)
IWCompTeeChart.dcr 1,21 KB (1.248 Bytes)
IWCompTeeChart.pas 2,67 KB (2.740 Bytes)
IWCompTeeChart.dcr - is missing -
Best regards,
Ralf
Misslungen
Best regards,
Ralf
Re: IntraWeb + VCL
Hello Ralf,
I've added the IWCompTeeChart.dcr to the zip in the downloads page.
Re: IntraWeb + VCL
Hello Yeray,
it works, thanks, the project I could successfully generate now:
Directory of C: \ Users \ ... \ TeeChart_2017_for_IntraWeb_14.0_and_RADStudio_XE10.1_Berlin_Std \ compiled
03.07.2018 08:53 130.560 DCLIW140TeeChart9_240.bpl
03.07.2018 08:53 10.993 DCLIW140TeeChart9_240.dcp
03.07.2018 08:53 46.592 IW140TeeChart9_240.bpl
03.07.2018 08:53 16.963 IW140TeeChart9_240.dcp
03.07.2018 08:53 8.762 IWCompTeeChart.dcu
03.07.2018 08:51 825 IWCompTeeChartReg.dcu
Unfortunately, there is now the problem that the packages can not be integrated:
[1] IW140TeeChart9_240.dproj - Projektverwaltung >> DCLIW140TeeChart9_240.bpl >> Installieren:
bds.exe - Systemfehler
Das Programm kann nicht gestartet werden, da IW140TeeChart9_240.bpl auf dem Computer fehlt. Installieren Sie das Programm erneut, um das Problem zu beheben.
OK
Fehler
Package C:\Users\...\TeeChart_2017_for_IntraWeb_14.0_and_RADStudio_XE10.1_Berlin_Std\compiled\DCLIW140TeeChart9_240.bpl kann nicht geladen werden.
Das angegebene Modul wurde nicht gefunden.
OK
[2] Alternatively via "Komponente | Packages installieren", Hinzufügen "DCLIW140TeeChart9_240.bpl":
OK
DCLIW140TeeChart9_240 - RAD Studio 10.1 Berlin - IWCompTeeChartReg [Erzeugt]
OK
I can not explain it because "DCLIW140TeeChart9_240.bpl" was created successfully (see above).
Do you have any idea?
Best regards,
Ralf
OK
Fehler
OK
OK
OK
Best regards,
Ralf
Re: IntraWeb + VCL
Try copying the "IW140TeeChart9_240.bpl" to "C:\Windows\SysWOW64".
