TSubChartTool and center title without AdjustFrame
Eic
Post by Eic » Wed Jun 28, 2017 3:32 pm
I want to center the title of my subgraph with AdjustFrame = false.
I use this code:
TChart * Chart1 = new TChart(this);
	Chart1->Parent = this;
	Chart1->Align = alClient;
	TSubChartTool *SubChart1 = new TSubChartTool(NULL);
	Chart1->Tools->Add(SubChart1);
	TChart * Chart2 = SubChart1->Charts->AddChart("MySubChart");
	Chart2->AddSeries(new TPointSeries(Chart1))->FillSampleValues();
	Chart2->Legend->Visible = true;
	Chart2->Title->Caption = "SubChart Title";
	Chart2->Title->Visible = true;
	Chart2->Title->AdjustFrame = false;
	SubChart1->Charts->Items[0]->Left = SubChart1->ParentChart->Width / 2;
	SubChart1->Charts->Items[0]->Width = SubChart1->ParentChart->Width / 2;
In this situation, the title is not centered above my graph, as you can see in the attachment file.
While waiting for the bug fix, is there a solution ?
SubChart Title.png (10.35 KiB) Viewed 9927 times
Re: TSubChartTool and center title without AdjustFrame
Post by Yeray » Fri Jun 30, 2017 10:09 am
I'm not sure to understand why do you set AdjustFrame to false if you want the title to move with the Chart. Removing that line of code the title move to the desired position, isn't it?
Eic
Post by Eic » Fri Jun 30, 2017 10:21 am
I just want my title to be centered on the graph + legend.
When the line is deleted, the title is centered above the graph, without taking into account the place taken by the plenum.
There may be another property to do that?
I attached the file "Test 2" with the expected centering in red for the title
Test 2.png (20.62 KiB) Viewed 9911 times
Post by Yeray » Fri Jun 30, 2017 11:32 am
You can use the SubChart's (Chart2 in your example) OnBeforeDrawChart event to manually reposition its Title. Ie (delphi):
procedure TForm1.SubChartBeforeDraw(Sender: TObject);
  with TChart(Sender) do
    Title.Top:=Top - Canvas.TextHeight(Title.Caption);
    Title.Left:=Left+(Width div 2) - (Canvas.TextWidth(Title.Caption) div 2);
Eic
Post by Eic » Fri Jun 30, 2017 11:44 am
Thank you for this temporary solution.
This bug will be corrected, or is it normal ?
Post by Yeray » Fri Jun 30, 2017 1:43 pm
The AdjustFrame property was designed to align the title with the ChartRect, not with the whole TChart.
If we changed this behaviour we'd break the compatibility. However, we could add some extra property to choose where to align the chart with more detail.
