Dual scale on plot
johnnix
Dual scale on plot
Post by johnnix » Thu Apr 13, 2017 1:37 pm
I am investigating the possibility to have dual X scales on a plot (attached is an example), is this something that TChart supports?
Thank you very much for your time
Re: Dual scale on plot
Post by Yeray » Tue Apr 18, 2017 10:59 am
One possibility could be to use both Horizontal axes (Top and Bottom) as in the following example:
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis; Series: TChartSeries;
  ValueIndex: Integer; var LabelText: string);
  if Sender = Chart1.Axes.Bottom then
    LabelText:= FormatFloat('#,##0', StrToFloatDef(LabelText, 0) / 10);
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=False;
  Chart1.MarginBottom:=10;
  with Chart1.AddSeries(THorizLineSeries) as THorizLineSeries do
    FillSampleValues;
    HorizAxis:=aBothHorizAxis;
  Chart1.Axes.Bottom.OtherSide:=True;
  Chart1.Axes.Bottom.Grid.Visible:=False;
  Chart1.Axes.Bottom.Ticks.Visible:=False;
  Chart1.Axes.Bottom.MinorTicks.Visible:=False;
Another similar possibility could be to use a SubAxis. Ie:
  if Sender = Chart1.Axes.Top.SubAxes[0] then
    LabelText:= FormatFloat('#,##0.##', StrToFloatDef(LabelText, 0) / 10);
    FillSampleValues;
    HorizAxis:=aTopAxis
  with Chart1.Axes.Top.SubAxes.Add do
    Axis.Visible:=False;
    LabelsFont.Name:=Chart1.Axes.Top.LabelsFont.Name;
johnnix
Post by johnnix » Tue Apr 18, 2017 2:45 pm
Hello Yeray,
Thank you very much for your prompt reply, I will definitely give it a try :)
John
