TMarksTipTool.Format.TextAlignment=taLeftJustify is not stored in .dfm instead taCenter is used when the application is compiled or the form is reopened in the IDE
Use the attached application (ChartTool1) for testing it.
TMarksTipTool.Format.TextAlignment=taLeftJustify not stored
- ErrorBarChart.7z
- (2.85 KiB) Downloaded 724 times
Re: TMarksTipTool.Format.TextAlignment=taLeftJustify not stored
The Alignment combobox in the TTextShapeEditor modifies the Alignment property, not the TextAlignment.
The TextAlignment can be modified in the Text tab in the TextShapeEditor, but his tab is hidden in the TMarksTipToolEdit.
