Axis title text doesn't obey html format
Technicon
Post by Technicon » Fri Jan 13, 2017 8:25 am
As you can see on that picture the frame behaves correctly but the text dose not breaking the line ( <BR> tag ).
Grzegorz
Re: Axis title text doesn't obey html format
Post by Yeray » Fri Jan 13, 2017 11:07 am
Have you set TextFormat to ttfHtml?
Chart1.Axes.Left.Title.TextFormat:=ttfHtml;
Technicon
Post by Technicon » Mon Jan 16, 2017 6:37 am
Yes I've set
The problem appear when you switch from GDI+ to GDI render.
Grzegorz
TeeChartTestCase4.zip
(90.06 KiB) Downloaded 899 times
Post by Sandra » Mon Jan 16, 2017 11:40 am
Hello technicon,
Unfortunately, I can't reproduce the problem you experiencing using the code below with TeeChart Pro VCL/FMX build 2016.19.161025:
	Chart1->View3D = false;
	Series1->FillSampleValues(100);
	//CharthtmlFormat
	Chart1->Axes->Left->Visible = true;
	Chart1->Axes->Left->Title->Text = "Html text";
	Chart1->Axes->Left->Title->TextFormat = ttfHtml;
	TeeGDIPlus1->TeePanel = Chart1;
	CheckBox1->Checked = true;
void __fastcall TForm1::CheckBox1Click(TObject *Sender)
		if (CheckBox1->Checked)
			TeeGDIPlus1->Active = true ;
			TeeGDIPlus1->Active = false;
Could you check the code above and confirm your results?
Thanks in advance
Technicon
Post by Technicon » Mon Jan 16, 2017 12:02 pm
Yes I can confirm
But You have to use html tag <BR> in text eg.
Chart1->Axes->Left->Title->Text = "Html<BR>text";
GDI+ enable
GDI+ disabled
Grzegorz
Post by Sandra » Tue Jan 17, 2017 9:23 am
Hello Technicon,
Many thanks for the update information.
After reviewing that again, I would like inform you the proble is already added in TeeChart VCL bugzilla tracker. Here's the link: http://bugs.teechart.net/show_bug.cgi?id=1343.
Feel free to add your mail to the ticket CC list to be automatically notified when an update arrives.
Thanks in advance
