Text position in TColorBandTool
JRadke
Post by JRadke » Thu Jan 12, 2017 9:36 am
I have assigned a TColorBandTool to the bottom axis of a chart and want to change the text position of the StartLine to the left-top corner.
I've tried the following code:
  with MyColorBandTool do begin
    StartLine.Annotation.Text := 'My text';
    StartLine.Annotation.Position := ppLeftTop;
but the text is always positioned at the middle of the axis.
Is there a way to chance it?
Kind Regards
Juergen
Re: Text position in TColorBandTool
Post by Yeray » Fri Jan 13, 2017 10:39 am
Hello Juergen,
The TColorBandTool embeds two TColorLineTools, and the TColorLineTool embeds a TAnnotationTool. However, the Position property is designed to be used with the TAnnotationTool alone. In these embedded TAnnotationTools the chart calculates the position automatically.
If you want further customization, you should hide the embedded annotation, create an independent TAnnotationTool and reposition it at the TColorBandTool OnChanged event. Ie:
var MyColorBand: TColorBandTool;
    MyStartAnnotation: TAnnotationTool;
  Chart1.View3D:=False;
  Chart1.Legend.Visible:=False;
  Chart1.AddSeries(TLineSeries).FillSampleValues;
  MyColorBand:=Chart1.Tools.Add(TColorBandTool) as TColorBandTool;
  with MyColorBand do
    Axis:=Chart1.Axes.Bottom;
    StartValue:=15;
    EndValue:=20;
    OnChanged:=ColorBandChange;
  MyStartAnnotation:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
  MyStartAnnotation.Text:='My text';
  Chart1.Draw;
  ColorBandChange(MyColorBand);
procedure TForm1.ColorBandChange(Sender: TObject);
  MyStartAnnotation.Shape.Left:=MyColorBand.Axis.CalcPosValue(MyColorBand.StartLine.Value);
  MyStartAnnotation.Shape.Top:=Chart1.ChartRect.Top;
JRadke
Post by JRadke » Fri Jan 13, 2017 12:54 pm
Hello Yeray,
Thank you for your reply.
I will take your example code as template for my further work.
Kind regards
Juergen
