DonutSeries
DonutSeries
I try to use DonutSeries with style like https://www.steema.com/uploads/products/Pie_Chart.png
but still ineffectual. Is it possible?
Re: DonutSeries
Yes, use SliceHeight to vary heights.
Eg.
series1.FillSampleValues();
Series1.SliceHeight[0]:= 1000;
Eg.
Re: DonutSeries
Ok thanks and one question more. So we have Hover with redline, How I can change redColor to some else color
- Untitled.png (10.18 KiB) Viewed 17383 times
Re: DonutSeries
When I pass data (2,1,1,15) to DonutSeries looks not expected. Here is example
How I can fix it?
How I can fix it?
- DonutSeries.rar
- (11.67 KiB) Downloaded 837 times
Re: DonutSeries
It's not a trivial problem that would probably need a complete redesign of the series to be fixed.
The only workaround I can think on at the moment is to change the rotation of the pie:
http://bugs.teechart.net/show_bug.cgi?id=935
http://bugs.teechart.net/show_bug.cgi?id=939
You can change this property:n2n wrote:So we have Hover with redline, How I can change redColor to some else color
Chart1.Legend.Selected.Hover.Font.Color:=clBlue;
I'm afraid I have to confirm this is a well known and difficult to solve problem with the TPieSeries in some situations.n2n wrote:When I pass data (2,1,1,15) to DonutSeries looks not expected.
DonutSeries1.RotationAngle:=50;
Re: DonutSeries
DonutSeries1.Rotate(358);
thanks.
- 3.png (3.98 KiB) Viewed 17339 times
- 2.png (4.89 KiB) Viewed 17335 times
Re: DonutSeries
Note OpenGL gives a better result. Ie:
Re: DonutSeries
Ok thanks. Can you give some example please?
Re: DonutSeries
I also added this
I took your example form here.n2n wrote:Can you give some example please?
uses TeeGLCanvas;
//Activate OpenGL
Chart1.Canvas:=TGLCanvas.Create;
Chart1.Aspect.Elevation:=40;
//Show Pen to better see the slices
DonutSeries1.Pen.Visible:=true;
//Make the Pen thinner
Chart1.Draw;
DonutSeries1.PiePen.Width:=0;
