I'm using D2007 with TeeChart Pro v2016.18 .160504 32bit VCL. Running on Windows 10.
I have created a Tdashboard form with a ChartPreviewer connected and a print button that just does ChartPreviewer1.Execute;
The chart looks fine in the previewer but when I print it renders the dashboard into a small square top left of the paper.
Is there a fix for this please?
Dashboard not printing correctly.
Re: Dashboard not printing correctly.
Attached is the demo project I'm using to test various options out.
- TDashBoard.zip
- Demo project and compiled exe.
- (10.63 KiB) Downloaded 2372 times
Using a virtual pdf printer I get this result with TeeChart v2016.18 that seems to be what you are reporting:
However, with the current sources I get this:
Which is not perfect because the gradients aren't supported in the export to pdf, but it works much better.
So the next maintenance release should fix this issue.
Thank you - when might the next maintenance release be available please?
Hello Nick,
Since you are a source code customer I can send you the affected units so you can extract them to your "Sources" folder overriding the v2016.18 units and rebuild the packages with TeeRecompile.
I'll send you a mail with the patch.
Thank you - the dashboard charts now print correctly BUT there are no titles either for the charts or the dashboard.
I see your titles use a white font. Note the printing routine sets a white background. So try changing your font color.
Doh! Sorry, I didn't spot that. Thank you.
