Sort by text is not stored
jls
Post by jls » Fri Sep 02, 2011 12:19 pm
I try to sort a series by text, it works, but the setting is not stored
Add a TdbChart
use the editior to set the sort value
close it
open the editor
sort setting is gone
I use
DXE
TeeChart VCL 2011.03
editor.zip
(100.67 KiB) Downloaded 698 times
Re: Sort by text is not stored
Post by Yeray » Mon Sep 05, 2011 8:21 am
Hello jls,
You are right. I've added it to the wish list to be revised for further releases (TV52015721)
jls
Post by jls » Tue Sep 06, 2011 7:27 am
do you think this will be included in next build?
Post by Yeray » Tue Sep 06, 2011 8:26 am
Hello jls,
I'm not sure about that.
I recommend you to be aware at the following channels for new release announcements and what's implemented on them: Support forum, RSS news feed, Twitter and Facebook.
tecsidelDesarrollo
Post by tecsidelDesarrollo » Thu Jul 07, 2016 2:28 pm
Hola,
Soy José Miguel Moreno de Tecsidel. La persistencia de la ordenación de las series por el texto parece que sigue sin estar solucionada. ¿Hay planes para ello a corto plazo o he de tocar el código fuente para solucionar dicho problema?.
Saludos.
Post by Yeray » Fri Jul 08, 2016 3:18 pm
Hola José Miguel,
tecsidelDesarrollo wrote:La persistencia de la ordenación de las series por el texto parece que sigue sin estar solucionada. ¿Hay planes para ello a corto plazo o he de tocar el código fuente para solucionar dicho problema?.
He movido el ticket al sistema publico:
http://bugs.teechart.net/show_bug.cgi?id=1576
Pero me temo que no puedo decirte si lo solucionaremos pronto.
