Keep the chart in 2D view when moving or rotating.
When move or rotate a chart using TeeCommander, the original 2D chart becomes a 3D chart by itself. How to keep a chart in 2D view when it been moved or rotated?
Best regards,
Xiushan
Best regards,
Xiushan
Re: Keep the chart in 2D view when moving or rotating.
Please find the attached files.
- fig2.jpg (42.59 KiB) Viewed 15101 times
- Fig1.jpg (35.83 KiB) Viewed 15088 times
That's a limitation on the rotation feature. It requires the chart to be in 3D to take effect.
Some alternatives I see:
- Set the Chart3DPercent to 0:
- Change your TLineSeries for TFastLineSeries.
Chart1.Chart3DPercent:=0;
Using TeeCommander to move, rotate or zoom, the chart properties (such as series color) change.
- 2.jpg (29.37 KiB) Viewed 15067 times
- 1.jpg (38.47 KiB) Viewed 15060 times
The second approach - using a TFastLineSeries instead of a TLineSeries - may make more sense in this case.
If you are using the first approach - using a TLineSeries with Chart3DPercent=0 - I'd suggest you to also set the series' LinePen.Color to be the series' Color. Ie:sripe wrote:Using TeeCommander to move, rotate or zoom, the chart properties (such as series color) change.
uses Series;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
FillSampleValues;
LinePen.Color:=Color;
Using the first approach, and the FormCreate procedure as follows:
It works well with TLineSeries. But, using TeeCommander to move, rotate or zoom TPolarSeries, there are two problems:
1. When moving or zooming the chart, it inclines (tilts, leans) by itself. (see Fig1)
2. When rotating the chart, the selected series (there is a ChartListBox1 on the Form, and ChartListBox1.SelectedSeries is active) and the Chart rotate, but the other PolarSeries do not follow the rotating command. (see Fig2)
procedure Tform1.FormCreate(Sender: TObject);
with Chart1 do
View3D := false;
View3DWalls := false;
Chart3DPercent := 0;
View3DOptions.Rotation := 0;
View3DOptions.Elevation := 360;
View3DOptions.Perspective := 0;
- Fig2.jpg (339.91 KiB) Viewed 15051 times
- Fig1.jpg (320.31 KiB) Viewed 15039 times
- Original.jpg (336.67 KiB) Viewed 15029 times
I've only placed a TChart and a TTeeCommander on a form and I use this code:
http://bugs.teechart.net/show_bug.cgi?id=1423
I see it moving/zooming deactivates the 3D, but other than that I can move/zoom the chart around without problems:sripe wrote:1. When moving or zooming the chart, it inclines (tilts, leans) by itself. (see Fig1)
var i: Integer;
with Chart1 do
//View3D := false;
Gradient.Visible:=false;
Title.Visible:=false;
for i:=0 to 1 do
with Chart1.AddSeries(TPolarSeries) as TPolarSeries do
FillSampleValues;
Pointer.Visible:=false;
Brush.Clear;
CircleBrush.Clear;
Pen.Color:=Color;
Pen.Width:=2;
I've added it to the public tracker:sripe wrote:2. When rotating the chart, the selected series (there is a ChartListBox1 on the Form, and ChartListBox1.SelectedSeries is active) and the Chart rotate, but the other PolarSeries do not follow the rotating command. (see Fig2)
Please press move or zoom button to test.
- Example4.zip
- (6.88 KiB) Downloaded 637 times
This is because when you start moving the chart it changes to 3D and the other properties (Elevation, Rotation, Orthogonal,...) take effect
Try setting Orthogonal to true or Elevation and Rotation to 360 after creating the series. Ie:
with Chart1 do
//Aspect.Orthogonal:=true;
Aspect.Elevation:=360;
Aspect.Rotation:=360;
Using TPolarSeries, it seems that the four axes (RightAxis, LeftAxis, TopAxis and BottomAxis) do not intersect the same point at the center, although I use the following codes to make the chart show in 2D view.
with Chart1 do
View3D := false;
Aspect.Rotation := 360;
Aspect.Elevation := 360;
Aspect.Perspective := 0;
Gradient.Visible := true;
How to make the four axes just right meet at the centre of a circle?
with Chart1 do
View3D := false;
- www.jpg (241.13 KiB) Viewed 14980 times
http://bugs.teechart.net/show_bug.cgi?id=1439
I see. I've added it to the public tracker:sripe wrote:Using TPolarSeries, it seems that the four axes (RightAxis, LeftAxis, TopAxis and BottomAxis) do not intersect the same point at the center, although I use the following codes to make the chart show in 2D view.
