THistogramSeries does not display correct (values not drawn)
THistogramSeries does not Draw all its values see image and code. In fact - if you hover gently over the TChart - you will see alot of invisible values...
- HistogramSeries.7z
- (1.44 KiB) Downloaded 786 times
- missing.jpg (142.71 KiB) Viewed 7477 times
Re: THistogramSeries does not display correct (values not drawn)
Thanks, that worked!
