TeeChart 2015.14.150120 VCL/FMX release available
Greetings!
Steema Support Central writes to inform you of the availability of the latest TeeChart VCL/FMX release.
TeeChart VCL/FMX customers may download the version at no-charge from the customer download page.
The 2015.14 update includes installers for all development environments supported.
The release also contains some new features, improvements and bug fixes. Release notes may be viewed at the version info page.
Re: TeeChart 2015.14.150120 VCL/FMX release available
I get the same error message with installation.
And there is no GDIPAPI.hpp and GDIPOBJ.hpp on the download pages.
- Uli
- Uli
It has now been out for a week. Is it just me or hasn't the "New and Improved Features"-page been updated yet?
Its not just you. To Steema: I'm guessing that most developers are not in the habit of downloading new versions unless they know what has changed/been fixed.
You are right. I'm afraid we haven't still updated the "New Features" document, but bugzilla is still fully operative:
http://tinyurl.com/TeeChartVCLFMX-2015-14-150120
It has now been over a month- Are there still plans to write something on http://www.steema.com/linkIn/WhatsNewVCL ?
I'm beginning to wonder if something bad is going on at Steema.. The bugzilla page is no sort of replacement for a proper what''s new page.
Hello everyone,
Many apologies for the delay here. The What's New? page for the 2015.14.150120 release has just been updated.
I'd never found out about that TDataImport class myself. Thank you for the thorough documentation!
Thanks for this!
I have TeeChart 2015 with sources and Delphi XE8. For the first time ever I am experiencing problems with TeeChart component installation. I removed previously installed version (2014)and deleted bpls from Windows\System32 folder but I am receiving errors when starting Delphi XE8. It says it cannot find modules. I attached a screenshoot so you can see what is my folder structure.
I just run TeeRecompile and check Delphi XE8. Recompilation goes fine (except GDIAPI hpp warning) but when I start delphi I am getting all those errors. Even if I try to install packages manually it doesn't work.
BTW: Installation of TeeChart 2014 into DelphiXE6 works fine.
Thanks for you help,
Aljosa
Aljosa
- errors
- steema_xe8.jpg (124.04 KiB) Viewed 41044 times
Hello Aljosa,
TeeChart v2015.14 was published on January this year. RAD XE8 has been published this month so TeeChart v2015.14 didn't support XE8.
We are working on a release supporting XE8 and we hope we can publish it asap as you can read here.
My bad. I didn't pay attention to it. Thanks.
www.teechart.net/support/viewtopic.php?f=3&t=15547
Just published!Yeray wrote:We are working on a release supporting XE8 and we hope we can publish it asap as you can read here.
