PDF export screwed-up chart
peterlepan
Post by peterlepan » Fri Sep 26, 2014 4:24 pm
I try to export a TeeChart to a pdf-file. The chart is from the template gallerie, the Concentric Donuts.
After export, the chart is screwed-up.
At the pdf-file, there are only the marks from the chart but no chart.
Please can you help me?
sincerely yours
Peter
Re: PDF export screwed-up chart
Post by Yeray » Mon Sep 29, 2014 1:00 pm
Hi Peter,
The concentric Donuts Template doesn't look as the one you posted above for me here.
Here it is how it looks for me:
And here it is the pdf I get with this code:
uses Series, TeePDFCanvas;
var i: Integer;
  Chart1.Title.Caption:='Concentric Donuts';
  for i:=0 to 2 do
    with Chart1.AddSeries(TPieSeries) as TPieSeries do
      FillSampleValues(4);
      Marks.Hide;
      MultiPie:=mpConcentric;
  TeeSaveToPDFFile(Chart1, 'C:\tmp\Chart1.pdf');
Chart1.zip
(7.45 KiB) Downloaded 866 times
As an alternative, you could print the chart with a virtual pdf printer:
Chart2.zip
(15.82 KiB) Downloaded 864 times
peterlepan
Post by peterlepan » Fri Oct 03, 2014 6:25 am
you are right, it looks a bit different but I use the concentric Donuts Template. I like to show the values as 100-perscent-columns, the middle of the circle is 100%. So I use the concentric Donuts and give all values the same width. Then I set the color of the values from outer (0%) to inner (100%) of the circle. What chart-type can I use as alternative to my solution? The new Rose Series show the values from inner circle to outer circle and use polar coordinates, but I need free scaling for the circle, not 360°.
Have you an idea what chart type better fit my needs?
Kind regards
Peter
Post by Yeray » Fri Oct 03, 2014 2:04 pm
Hello Peter,
I've been trying to do a demo using the Rose series. I found some issues but I one problem I can't find how to workaround: some circle labels seem not to be drawn depending on the number of values.
RoseTest.zip
(2.04 KiB) Downloaded 852 times
On the other hand, we'd be pleased to investigate the problem exporting the concentric pies, but we'd need a simple example project we can run as-is to reproduce the problem here.
peterlepan
Post by peterlepan » Fri Oct 03, 2014 7:17 pm
Hello Yeray,
here is al little sample projekt about my problem.
By the way, an other problem is the positioning of the marks. I set the Marks on the most outer series, but the width of the serie is so big, that some other series are covered. I use curious parameters for the marks-arrow as workaround. Is there an other way in my case to fix the width of the outer serie independently from the marks?
donuts.zip
(54.23 KiB) Downloaded 871 times
Kind regards
Peter
Post by Yeray » Mon Oct 06, 2014 11:00 am
Hi Peter,
peterlepan wrote:here is al little sample projekt about my problem.
I could reproduce the problem with your project when exporting the chart to a pdf.
However, it seems to work fine if I print the chart using a virtual pdf printer, instead of exporting the chart to a pdf.
Yeray wrote:I've been trying to do a demo using the Rose series. I found some issues but I one problem I can't find how to workaround: some circle labels seem not to be drawn depending on the number of values.
I've corrected the example above and this seems to work better.
Exporting to a pdf file works better than with the TPieSeries, but not perfect: the labels in the main chart disappear. However, printing the chart with a virtual pdf printer also works fine:
uses TeePDFCanvas;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TRoseSeries) as TRoseSeries do
    Pointer.Visible:=false;
    Pen.Visible:=false;
    Color:=clWhite;
    CircleBackColor:=RGB(0,0,128);
    GetHorizAxis.Grid.Visible:=false;
    GetVertAxis.Grid.Visible:=false;
    GetHorizAxis.MinorTicks.Visible:=false;
    CircleLabelsRotated:=true;
    LabelsMargin:=10;
    OnGetCircleLabel:=roseGetCircleLabels;
  Chart1.Axes.Visible:=false;
  TrackBar1.Max:=200;
  TrackBar1.Min:=10;
  TrackBar1.Position:=29;
  TrackBar1.Frequency:=10;
procedure TForm1.recalcAngles;
var i: Integer;
  with Chart1[0] as TRoseSeries do
    for i:=0 to Count-1 do
      AngleValue[i]:=i*360/Count;
    AngleIncrement:=(AngleValue[1]-AngleValue[0]) / 2;
procedure TForm1.roseGetCircleLabels(Sender:TCustomPolarSeries; const Angle:Double; Index:Integer;
                                     var Text:String);
var i: Integer;
  Text:='';
      if Round(Angle-AngleIncrement)=Round(AngleValue[i]) then
        Text:=Labels[i];
procedure TForm1.TrackBar1Change(Sender: TObject);
var i, tmpValue: Integer;
    Clear;
    for i:=0 to TrackBar1.Position-1 do
      tmpValue:=Round(random*100);
      AddPolar(tmpValue, tmpValue, IntToStr(tmpValue));
      recalcAngles;
  Label1.Caption:='Num Values: ' + IntToStr(TrackBar1.Position);
peterlepan
Post by peterlepan » Tue Oct 07, 2014 6:32 am
your sample works fine, but I have one problem. I need to show the values from outer to inner. The outer of the circle is 0% and the center of the circle stands for 100%. If I show the difference to 100% with the rose-serie, I see no chance to change the color for a single value from outer to inner. These color is set with the CircleBackColor.
Oh, I have an idea! I use a second rose-serie to set the color of my single values!
Thank your for your inspiration!
Best regards
Peter
peterlepan
Post by peterlepan » Tue Oct 07, 2014 6:59 am
only one question, how can I put the labels in the foreground? I have the labels taken in the inner of the circle, but some of them are invisible because they are covered from the rose-serie.
Have you a solution for this problem?
Best regards
Peter
Post by Yeray » Tue Oct 07, 2014 7:20 am
Hi Peter,
peterlepan wrote:Oh, I have an idea! I use a second rose-serie to set the color of my single values!
Great!
I'm glad to be helpful!
peterlepan wrote:only one question, how can I put the labels in the foreground? I have the labels taken in the inner of the circle, but some of them are invisible because they are covered from the rose-serie.
There's a property for that:
Series1.CircleLabelsInside:=false;
peterlepan
Post by peterlepan » Tue Oct 07, 2014 11:02 pm
the rose serie has a cleaner look then the concentric donuts. But I have one Problem. I like to put the labels inside the circle, to save some space around the chart. If the labels-text get a bit longer then 3 numbers, the labels on the left side are not symmetric positioned to the labels on the right side:
The labels loose the assignment to its chart-values.
If I put the marks at the concentric donuts inside the circle, I nearly get a circle:
Each segment get its right label.
Is there an option at the rose serie, to position the labels in the circle without loosing the assignment to the values?
Best regards
Peter
Post by Yeray » Wed Oct 08, 2014 11:23 am
peterlepan
Post by peterlepan » Sun Feb 08, 2015 11:44 pm
I see a new version of TeeChart, have you put some improvements to the rose-serie? (especially labels?)
Best regards
Peter
Post by Yeray » Mon Feb 09, 2015 2:08 pm
peterlepan wrote:I see a new version of TeeChart, have you put some improvements to the rose-serie? (especially labels?)
I'm afraid not yet, Peter.
I've incremented the priority of the ticket Improve labels in TRoseSeries
jdom
Post by jdom » Wed Feb 11, 2015 10:39 am
sorry for the minor threadjack, am not sure how to upvote for features, but would like to add an enthusiastic vote for moving "Rounded/Circled Segments in the TRoseSeries" up the priority list. thank you! (if it will be part of the Xamarin.Forms release, too...)
Post by Yeray » Wed Feb 11, 2015 12:57 pm
jdom wrote:sorry for the minor threadjack, am not sure how to upvote for features, but would like to add an enthusiastic vote for moving "Rounded/Circled Segments in the TRoseSeries" up the priority list. thank you! (if it will be part of the Xamarin.Forms release, too...)
Added to .NET Xamarin.Forms:
http://bugs.teechart.net/show_bug.cgi?id=1132
Feel free to add your mail to the CC list of any ticket to be automatically notified when an update arrives.
