TeeChart 2015.14.150120 VCL/FMX release available
Post by Narcís » Fri Jan 23, 2015 9:59 am
Greetings!
Steema Support Central writes to inform you of the availability of the latest TeeChart VCL/FMX release.
TeeChart VCL/FMX customers may download the version at no-charge from the customer download page.
The 2015.14 update includes installers for all development environments supported.
The release also contains some new features, improvements and bug fixes. Release notes may be viewed at the version info page.
ulibru
Re: TeeChart 2015.14.150120 VCL/FMX release available
Post by ulibru » Mon Jan 26, 2015 4:01 pm
I get the same error message with installation.
And there is no GDIPAPI.hpp and GDIPOBJ.hpp on the download pages.
- Uli
Post by Yeray » Tue Jan 27, 2015 8:46 am
Hi Uli,
I've just replied this here:
http://www.teechart.net/support/viewtop ... 299#p68299
jens.mertelmeyer
Post by jens.mertelmeyer » Fri Jan 30, 2015 5:57 pm
It has now been out for a week. Is it just me or hasn't the "New and Improved Features"-page been updated yet?
CharlieHeaps
Post by CharlieHeaps » Fri Jan 30, 2015 6:24 pm
Its not just you. To Steema: I'm guessing that most developers are not in the habit of downloading new versions unless they know what has changed/been fixed.
Post by Yeray » Mon Feb 02, 2015 8:16 am
You are right. I'm afraid we haven't still updated the "New Features" document, but bugzilla is still fully operative:
http://tinyurl.com/TeeChartVCLFMX-2015-14-150120
jens.mertelmeyer
Post by jens.mertelmeyer » Wed Feb 25, 2015 8:49 am
It has now been over a month- Are there still plans to write something on http://www.steema.com/linkIn/WhatsNewVCL ?
CharlieHeaps
Post by CharlieHeaps » Fri Feb 27, 2015 8:42 pm
I'm beginning to wonder if something bad is going on at Steema.. The bugzilla page is no sort of replacement for a proper what''s new page.
Post by Narcís » Wed Mar 11, 2015 11:35 am
Hello everyone,
Many apologies for the delay here. The What's New? page for the 2015.14.150120 release has just been updated.
jens.mertelmeyer
Post by jens.mertelmeyer » Thu Mar 12, 2015 10:11 am
I'd never found out about that TDataImport class myself. Thank you for the thorough documentation!
CharlieHeaps
Post by CharlieHeaps » Thu Mar 12, 2015 8:06 pm
Thanks for this!
PoLabs
Post by PoLabs » Thu Apr 16, 2015 5:11 pm
I have TeeChart 2015 with sources and Delphi XE8. For the first time ever I am experiencing problems with TeeChart component installation. I removed previously installed version (2014)and deleted bpls from Windows\System32 folder but I am receiving errors when starting Delphi XE8. It says it cannot find modules. I attached a screenshoot so you can see what is my folder structure.
I just run TeeRecompile and check Delphi XE8. Recompilation goes fine (except GDIAPI hpp warning) but when I start delphi I am getting all those errors. Even if I try to install packages manually it doesn't work.
BTW: Installation of TeeChart 2014 into DelphiXE6 works fine.
Thanks for you help,
Aljosa
errors
Post by Yeray » Fri Apr 17, 2015 8:55 am
Hello Aljosa,
TeeChart v2015.14 was published on January this year. RAD XE8 has been published this month so TeeChart v2015.14 didn't support XE8.
We are working on a release supporting XE8 and we hope we can publish it asap as you can read here.
PoLabs
Post by PoLabs » Mon Apr 20, 2015 12:36 pm
My bad. I didn't pay attention to it. Thanks.
Post by Yeray » Thu Apr 23, 2015 12:38 pm
Yeray wrote:We are working on a release supporting XE8 and we hope we can publish it asap as you can read here.
Just published!
www.teechart.net/support/viewtopic.php?f=3&t=15547
