How to add and remote a FastLineSeries in runtime ?
Sciensoria
Post by Sciensoria » Sun Mar 22, 2009 12:34 am
I want to add and remove series to and from a Tchart. I suppose that AddSeries can be used for adding series. But for removing the series, there is very few information in the user's guide. Could you provide some examples about adding and deleting series from a Chart ?
Thank you in advance.
Patrick :roll:
Post by Yeray » Mon Mar 23, 2009 10:07 am
Hi Patrick,
You could use the series' variable to remove it from the chart:
var line1: TLineSeries;
point1: TPointSeries;
  line1 := TLineSeries.Create(nil);
  point1 := TPointSeries.Create(nil);
  Chart1.AddSeries(line1);
  Chart1.AddSeries(point1);
  line1.FillSampleValues(25);
  point1.FillSampleValues(25);
  Chart1.RemoveSeries(point1);
  point1.Free;
Or you could remove it using the series' index in the series list:
Chart1.RemoveSeries(1);
Sciensoria
Thank you
Post by Sciensoria » Mon Mar 23, 2009 11:24 pm
Many thanks for the help. This works quite well.
Re: How to add and remote a FastLineSeries in runtime ?
Post by Yeray » Thu Oct 02, 2014 7:50 am
Hi Patrick,
I've split your new post into a new thread:
http://www.teechart.net/support/viewtop ... =3&t=15208
