45 deg angle bottom axis issue
MartinF
Post by MartinF » Tue Aug 19, 2014 5:33 pm
I was looking for a solution to this... http://codeverge.com/embarcadero.delphi ... om/1091037 so upgraded from 2013.9 Pro to 2014.11 Pro and it looks like the problem still exists.
Is there any estimate of a fix? If at all.
Thx
MartinF
PS a brief description "The problem is not limited to date formats. When LabelsAngle>0 (I tried 45, 60 90) the labels of bottomAxis will go thru the axis.
I get the impression that the margins and padding do not work at the bottom. With LabelsAngle=0 and two-line labels, the bottom row will touch the border whatever I try with the margins and padding."
Re: 45 deg angle bottom axis issue
Post by Yeray » Wed Aug 20, 2014 9:59 am
Hi Martin,
The following code seems to work fine for me here with TeeChart v2014.11 and XE5:
uses VCLTee.Series, VCLTee.TeeConst;
  Chart1.View3D:=false;
  Chart1.AddSeries(TLineSeries).FillSampleValues;
  Chart1.Axes.Bottom.LabelsAngle:=90;
Could you please try the project attached to see what gives for you?
testLabelsAngle.zip
(1.57 KiB) Downloaded 352 times
