I've just upgraded one of my projects from BCB XE to BCB EX5. It compiled ok, but when I run the program, at first the legend displays ok, but when I refresh ChartSeries, the legend turned in to a black box. I've attached two images. One is before refreshing hte series and one is after.
I'm using BCB XE5 with TChart Pro v2014.10.140220 32 bit VCL.
TChart Legend Black
TChart Legend Black
- after refresh series
- Capture2.jpg (78.31 KiB) Viewed 5924 times
- before refresh sereis
- Capture1.jpg (80.85 KiB) Viewed 5913 times
Re: TChart Legend Black
We've identified a similar problem here. Are you using GDI?
If you can't switch to GDI+, can you please arrange a simple example project we can run as-is to reproduce the problem here, so we can try to suggest you another workaround?
Yes, I'm using GDI+. I switched to GDI and still have the same issue.
Hi Bill,
Can you arrange a simple example project we can run as-is to reproduce the problem here?Bill wrote:Yes, I'm using GDI+. I switched to GDI and still have the same issue.
