Legend set height
Kai
Legend set height
Post by Kai » Wed Apr 30, 2014 8:22 am
We are using the TeeChartStandard2014 package.
I use the follwing to create a large TBarSeries series Series1.FillSampleValues(100);
The result looks like this:
Is it possible the set a fixed height for the legend and use a custom scrollbar?
If i add a scrollbar i can navigate with Chart1.Legend.FirstValue := ScrollBarLegend.Position;
I hope I could describe the problem well.
Thanx.
Re: Legend set height
Post by Yeray » Wed Apr 30, 2014 9:15 am
Hello Kai,
TeeChart Pro includes the TLegendScrollBar between the Chart Tools.
Here you have an example of it:
uses Series, TeeLegendScrollBar;
var i: Integer;
  with Chart1.AddSeries(TBarSeries) do
    for i:=0 to 99 do
      Add(i);
  Chart1.Legend.Alignment:=laTop;
  Chart1.Tools.Add(TLegendScrollBar);
  Chart1.Legend.MaxNumRows:=4;
Note this tool is designed for the default vertical Legend Alignment (aka laLeft/laRight). In an horizontal Alignment (aka alTop/alBottom), when you increment the position of the scrollbar a unit, the top-left element of the legend disappears, all the other elements move a step left (the elements on the left move a row above and to the right edge), and a new element appears on the right-bottom.
This may be better explained with two images.
Here it is how it looks when you start the application running the code above:
And this is how it looks if you press the right arrow on the legend scrollbar once:
The alternative would be draw your shapes and texts manually at OnAfterDraw event.
Kai
Post by Kai » Wed Apr 30, 2014 1:43 pm
Hello Yeray,
thank you for your answer.
If i use something like that:
var
  intI: Integer;
  ChartAccounting.Legend.Alignment := laTop;
  for intI := 0 to 100 do
    with frmChart.ChartAccounting.AddSeries(TBarSeries) as TBarSeries do
      FillSampleValues(1);
  frmChart.ChartAccounting.Draw();
It looks like that:
So the problem is that there are missing series in the legend.
How can i solve this? Thanx.
Post by Yeray » Wed Apr 30, 2014 2:19 pm
Hi Kai,
Kai wrote:So the problem is that there are missing series in the legend.
If you don't specify the Legend's MaxNumRows, the maximum number of rows will be 10. In the case above, to fit 101 items you'll need 21 rows:
ChartAccounting.Legend.MaxNumRows:=21;
Kai
Post by Kai » Wed Apr 30, 2014 2:24 pm
Works :D
Thank you.
Do you have a short sample, how i can calculate the needed value of MaxNumRows?
Post by Yeray » Wed Apr 30, 2014 2:46 pm
Hi Kai,
Kai wrote:Do you have a short sample, how i can calculate the needed value of MaxNumRows?
We take care of a few aspects of the chart to calculate this.
This is our ItemHeight function:
Function TCustomChartLegend.CalcItemHeight:Integer;
  result:=ParentChart.Canvas.FontHeight;
  if Symbol.Visible then
     if Symbol.HeightUnits=lcsPercent then
       if Symbol.Height>100 then
          result:=Round(result*Symbol.Height*0.01);
     end
       result:=Max(result,Symbol.Height);
  if HasCheckBoxes then
     result:=Math.Max(6+TeeCheckBoxSize,result);
  Inc(result,FVertSpacing);
  if Vertical and DividingLines.Visible then
     result:=result+{$IFDEF FMX}Round{$ENDIF}(DividingLines.Width);
And you also need to know the YLegend. We use this FirstItemTop function for that:
Function TCustomChartLegend.FirstItemTop:Integer;
  result:={$IFDEF FMX}Round{$ENDIF}(ShapeBounds.Top);
  if Frame.Visible then
     Inc(result,({$IFDEF FMX}Round{$ENDIF}(Frame.Width) div 2));
  if IDrawTitle then
     Inc(result,{$IFDEF FMX}Round{$ENDIF}(Title.Height)+2);
Then, after having calculated this, we will be able to call our MaxLegendRows function:
  Function MaxLegendRows(YLegend,ItemHeight:Integer):Integer;
    With ParentChart do
    Begin
      if (YLegend<ChartRect.Bottom) and (ItemHeight>0) then
      Begin
        result:={$IFDEF FMX}Round{$ENDIF}(ChartHeight-FrameWidth-YLegend+ChartRect.Top) div ItemHeight;
        result:=Math.Min(result,TotalLegendItems);
      end
      else result:=0;
This is how we call these functions in the Legend CalcRect function:
  ItemHeight:=CalcItemHeight;
    NumRows:=MaxLegendRows(FirstItemTop,ItemHeight);
    if MaxNumRows <> 0 then
       NumRows:=Math.Min(NumRows,MaxNumRows);
The above is an extract of Chart.pas, part of TeeChart sources. Being just a snipped of code means this won't probably compile in an application different than TeeChart sources but can give you an idea of what calculations you should make to emulate a similar effect.
Kai
Post by Kai » Fri May 02, 2014 7:06 am
Thank you very much. I will try it.
