Drawing bottom axis label in red
TestAlways
Post by TestAlways » Mon Apr 28, 2014 11:07 pm
2014.11.140409
In the attached demo, I have code that use to work (I believe Steema support provided similar code) to draw selected labels on the bottom axis in red. This one should draw every other label in red. It doesn't work in the latest version.
How should this be coded?
Ed Dressel
Draw Axis Label.zip
(2.2 KiB) Downloaded 701 times
Re: Drawing bottom axis label in red
Post by Yeray » Tue Apr 29, 2014 9:43 am
Hi Ed,
Instead of modifying the Canvas Font, you could modify the Bottom Axis LabelsFont in the OnDrawLabel event, making sure you also handle the "else" situation setting the default properties to the LabelsFont. Ie:
    if (lIdx > -1) and (FDrawRedIndexes.IndexOf(TObject(lIdx)) > -1) then
      {lChart.Canvas.Font.Color := clRed;
      lChart.Canvas.Font.Style := [fsBold];}
      lChart.Axes.Bottom.LabelsFont.Color:=clRed;
      lChart.Axes.Bottom.LabelsFont.Style:=[fsBold];
    end
      lChart.Axes.Bottom.LabelsFont.Color:=clBlack;
      lChart.Axes.Bottom.LabelsFont.Style:=[];
As an alternative, the latest TeeChart versions allow you yo to directly set the LabelsList in your Bottom Axis, instead of having to use the OnDrawLabel event. Ie:
constructor TForm1.Create(aOwner: TComponent);
var
  lValue: Double;
  I, J: Integer;
  lIdx: Integer;
  aX: Integer;
  lCalcXPos: Integer;
  lMinOffBy: Integer;
  lOffBy: Integer;
  lSrs: TChartSeries;
  inherited;
  Caption := TeeMsg_Version;
  FDrawRedIndexes := TList.Create;
  SEries1.Clear;
  lValue := 1000.0;
  for I := 0 to 19 do
    Series1.Add(lValue);
    lValue := lValue * 1.03;
    if (I mod 2) = 0 then
      FDrawRedIndexes.Add(TObject(I));
  //Chart1.BottomAxis.OnDrawLabel := ChartBottomAxisDrawLabel;
  Chart1.Draw;
  with Chart1.Axes.Bottom.Items do
    Automatic:=false;
    for I := 0 to Count-1 do
      lSrs := Chart1.Series[0];
      lIdx := -1;
      aX := Item[I].LabelPos;
      lMinOffBy := MaxInt;
      for J := lSrs.Count - 1 downto 0 do
        lCalcXPos := lSrs.CalcXPos(J);
        lOffBy := abs(aX - lCalcXPos);
        if (lOffBy < lMinOffBy) then
          lIdx := J;
          lMinOffBy := lOffBy;
        Item[I].Format.Font.Color := clRed;
        Item[I].Format.Font.Style := [fsBold];
