TeeCanvas3d + Antialias drawing LineSeries dualcolor
JES
Re: TeeCanvas3d + Antialias drawing LineSeries dualcolor
Post by JES » Mon Mar 10, 2014 12:00 pm
I don't think that you have compiled your version with global project define: TEEANTIALIAS (because in picture you have two pixels width horizontal line).
So your version uses actually GDI+ library to draw that antialias version.
When TeeChart sources are compiled with TEEANTIALIAS define it still draws non horizontal lines in wrong color.
Janne
Post by Yeray » Fri Mar 14, 2014 11:50 am
Hi Janne,
We're studying the problem and we'll be back here asap.
Post by Yeray » Fri Mar 14, 2014 3:02 pm
Hello Janne,
I'll send a beta version of the TeeChart sources to the mail account you have registered in this forum so you can test this.
Now, adding the TEEANTIALIAS define, we get this:
Note the color isn't perfect. This is because our AntiAlias is doing a blending with the background and it gives blue-greyed line.
JES
Post by JES » Tue Mar 18, 2014 6:32 am
it is better now, but when data is dense and lines overlaps each other it still looks bad.
Can it be fixed like it was in older versions.
Dense data
Data that does not overlap lines is better (actually this kind of data/drawing GDI+ is good)
Janne
Post by Yeray » Tue Mar 18, 2014 3:44 pm
Hi Janne,
It doesn't look so bad for me only changing the color and the number of values.
Isn't this what you get with the example some posts above and the following changes?
  with Chart1.AddSeries(TFastLineSeries) as TFastLineSeries do
    Color:=clRed;
    //AddArray([10,10,12,1,15,13,13]);
    FillSampleValues(100000);
    BeforeDrawValues:=SeriesBeforeDrawValues;
    AfterDrawValues:=SeriesAfterDrawValues;
On the other hand, having so many overlapping points makes the chart difficult to read. You may be interested on setting the TFastLineSeries DrawAllPoints property to false or reducing the number of points with the TDownSamplingFunction.
JES
Post by JES » Tue Mar 18, 2014 5:32 pm
it looks same as your sample.
I am drawing process data values and user can choose freely resolution, so it can contain a lot of values (and I don't want to reduce visible points programmatically, eq. DrawAllPoints:=false; if user have choosen to see accurate data).
Why is it not possible to get old Antialias drawing back, this does not look good (I'm using now GDI drawing with these new versions but old Antialias was much nicer looking).
This is not acceptable
Janne
JES
Post by JES » Mon Apr 07, 2014 5:56 am
any news on this issue?
Janne
Post by Yeray » Mon Apr 07, 2014 11:57 am
Hi Janne,
I'm sorry for the late reply here. We're studying what changed and what's the best way to go we can suggest you.
Post by Yeray » Tue Apr 08, 2014 2:28 pm
Hi Janne,
Yeray wrote:I'm sorry for the late reply here. We're studying what changed and what's the best way to go we can suggest you.
We've just corrected it.
Since the fix is simple and you are a source code customer, we can tell you the changes to apply. At TeeAntiAlias.pas you'll find the BlendColor (in your case it may be BlendColor1):
procedure TAntiAliasCanvas.BlendColor(const AX,AY:Integer; const Dist:Single);
At the beginning of this function you'll find this:
      if IFilter.RGBA then
      {$R-}
      with IFilter.LinesRGBA[AY,AX] do
      {$IFDEF WASRANGE}
      {$R+}
      {$ENDIF}
        // BGR
        Red:=Round(Dist*(Red-r))    + r;
        Green:=Round(Dist*(Green-g))+ g;
        Blue:=Round(Dist*(Blue-b))  + b;
      end
Modify the above for this:
      {$R-}
      {$IFDEF WASRANGE}
      {$R+}
      {$ENDIF}
        // BGR
        Red:=Round(Dist*(Red-b))    + b;
        Blue:=Round(Dist*(Blue-r))  + r;
      end
JES
Post by JES » Thu Apr 10, 2014 5:12 am
great, now it works fine, thanks!
Janne
