Hello.
Am running 2013 Pro VCL. (delphi xe5)
Can replicate this by simply dropping a TDBChart component on the form, and use the Chart Editor.
Select 'Data', and then change some of the values to zero - you will see the pie (3D) display is corrupt (edges).
If I could just add a legend for the zero value without drawing the empty slice that would be fine.
This behavior only happends on 2013 - delphi xe5 teechart standard is fine.
Pie Chart containing zero value slices corrupts the display
- teecharterror.png (35.98 KiB) Viewed 3533 times
Re: Pie Chart containing zero value slices corrupts the display
Hi arabica,
I'm not able to reproduce the issue here either at design-time or run-time using this code:
If the code snippet above reproduces the problem at your end then you can expect this being fixed in the next maintenance release which will be probably published next week.
uses VCLTee.Series;
Chart1.AddSeries(TPieSeries.Create(Self)).FillSampleValues;
Chart1[0].YValues[4]:=0;
