TeeChart 2013 and Legend Symbol Size
Errol
Post by Errol » Tue Feb 18, 2014 4:53 am
With TeeChart 8, the symbol size in the legend of line graphs matched the symbol size used in the graph, up to a maximum 5x5 symbol. See the attached images tagged with TeeChart8. With TeeChart 2013, however, the symbol size is always at one large size and very wide, especially for our multiple graphs (see images tagged with TeeChart2013). I tracked the cause of the problem down to a change in the parameters for the Pointer.DrawPointer command in TeePointerDrawLegend in series.pas.
When I replaced this with the parameters fromTeeChart8, the legend symbol is now drawn correctly. Will Steema restore the DrawPointer parameters to those in TeeChart 8, or do I have to write some overloaded procedure in my code to obtain the output I require. If the latter, can you please indicate where I would need to introduce the overloaded procedure as the TeePointerDrawLegend is deep within the TeeChart code.
Procedure TeePointerDrawLegend(const Pointer:TSeriesPointer; AColor:TColor;
                               Const Rect:TRect; DrawPen:Boolean;
                               AStyle:TSeriesPointerStyle);
var tmpHoriz : Integer;
    tmpVert  : Integer;
    tmpPenW  : Integer;
    tmpX     : Integer;
    tmpY     : Integer;
    tmp      : Integer;
  if Assigned(Pointer.ParentChart) then
// code
// replaced this expression in TeeChart2013 version
{      Pointer.DrawPointer(Pointer.ParentChart.Canvas,
                          False,
                          tmpX,
                          tmpY,
                          tmpHoriz, //Math.Min(Pointer.HorizSize,tmpHoriz),
                          tmpVert, //Math.Min(Pointer.VertSize,tmpVert),
                          AColor,AStyle);}
// with this one from TeeChart 8
                          False,
                          tmpX,
                          tmpY,
                          AColor,AStyle);
Re: TeeChart 2013 and Legend Symbol Size
Post by Narcís » Wed Feb 19, 2014 3:33 pm
Hi Errol,
This has been improved in our current sources. We are finalizing the details for a new maintenance release. We expect it to be out before the end of the month. What I get with our internal sources is this:
Is this similar to what you'd expect?
Errol
Post by Errol » Wed Feb 19, 2014 8:08 pm
Hi Narcis
Yes this looks similar to what I expect, except I would like to also see the line colour and line type in the legend as a line through the symbol (usually shorter than that shown in MultipleGraph_TeeChart8.png - our Multiple Graph legends are coded). I'll stay with the Source Code change at the moment until your maintenance release comes out, and then see if I have to develop an override version of TeePointerDrawLegend.
Thanks and regards
Errol
Post by Narcís » Thu Feb 20, 2014 8:23 am
Hi Errol,
Thanks for your feedback. Also feel free to submit your functionality requests at Steema Software's bugzilla platform: http://bugs.teechart.net/
Post by Yeray » Thu Feb 20, 2014 8:50 am
Hi Errol,
Errol wrote:Yes this looks similar to what I expect, except I would like to also see the line colour and line type in the legend as a line through the symbol (usually shorter than that shown in MultipleGraph_TeeChart8.png - our Multiple Graph legends are coded). I'll stay with the Source Code change at the moment until your maintenance release comes out, and then see if I have to develop an override version of TeePointerDrawLegend.
Note you can widen the legend symbol through the Legend.Symbol.Width property. Ie:
uses Series;
var i: Integer;
  Chart1.View3D:=false;
  for i:=0 to 2 do
      FillSampleValues;
      Pointer.Visible:=true;
      Pointer.Style:=TSeriesPointerStyle(i);
  Chart1.Legend.Alignment:=laBottom;
  Chart1.Legend.Symbol.Width:=50;
