Barseries, overlapping bars
Hi.
What I would like to do is have x number of points(x-axis) with y numbers of barseries to each x-value.
In this case to points (x) 20111, 42111 and 15 barseries (y) to each.
How can I prevent the bars form overlapping?
And I also want an spacing between the points on the x-axis.
Something similar like in the After.png. But not such an big spacing.
After.png spacing is created by adding x-axis point 20112
I have uploaded an zip attachment containing Before/after
JohnA
JohnA
- Barseries.zip
- (131.57 KiB) Downloaded 422 times
Re: Barseries, overlapping bars
Hi JohnA,
Are you using MultiBar property? I recommend you to have a look at the examples at All Features\Welcome!\Chart Styles\Standard\Bar\Side All Layout in the new features demo, available at TeeChart's program group. If this doesn't help please attach a simple example project we can run "as-is" to reproduce the problem here.
Hi.
I can not find the features demo.
It is not located under the TeeChart's program group.
thanks
thanks
- Uten navn.png (7.43 KiB) Viewed 10229 times
Hi JohnA,
That's the source code version. Demos, tutorials and documentation ares only included with the binary installers to keep the source code version as small as possible. Moreover, source code customers also have access to the binary installers. We recommend to install them prior to the source code version to have access to those resources.
Hi.
I uninstalled with source code
Installed binary
installed with source code and recompiled.
When I'm starting the new features demo I get this error.
Installed binary
- Skjermbilde.PNG (16.8 KiB) Viewed 10229 times
In case you do not understand norwegian
roughly translated to "Procedure Entry Point did not exist in the dynamic link library"
Hi JohnA,
That's probably because the .bpl it was compiled with no longer exists as it was overwritten by the source code generated package. In that case you should open the demo project (Tee9New.dpr) at C:\Program Files\Steema Software\TeeChart 2013 for RAD XE4\Examples\Features, for example, and compile it with your current TeeChart version.
Hi.
I was not able to solve this with the multibar property.
I have attached an sample project demonstrating the problem.
You can se that the bars overlapping.
What I'm looking for is 2 groups of bars: 20111 and 42111 (x-values)
and a space between them
thanks
thanks
- BarSeries.zip
- (82.79 KiB) Downloaded 409 times
Hi JohnA,
What about setting a smaller bar width percent?
(Chart1[i] as TBarSeries).BarWidthPercent:=75;
The chart look better now
