Crash when using Pie Chart
JeffS
Post by JeffS » Tue Sep 17, 2013 1:56 pm
I am porting an application from Codegear 2007 to XE4. We have acquired the full version of Teechart.
But the use of TPieSeries in our dfm file, causes the crash of our application (though it was working fine when compiled with 2007 tools and librairies).
Here is the call stack:
:5005eb5e rtl180.@System@TObject@InitInstance$qqrpv + 0x1e
:00886226 ; TPieSeries
:50160a80 ; E:\Naviplex2\rtl180.bpl
:50160cad rtl180.@System@Classes@TReader@ReadComponent$qqrp25System@Classes@TComponent + 0x8d
:50160f5e rtl180.@System@Classes@TReader@ReadDataInner$qqrxp25System@Classes@TComponent + 0x8e
:50160ecc rtl180.@System@Classes@TReader@ReadData$qqrxp25System@Classes@TComponent + 0x6c
:5016dfc6 rtl180.@System@Classes@TComponent@ReadState$qqrp22System@Classes@TReader + 0x6
:008eca3f Vcltee::Teeprocs::TCustomTeePanel::ReadState + 0x27
:50160d42 ; E:\Naviplex2\rtl180.bpl
:50160e9d rtl180.@System@Classes@TReader@ReadData$qqrxp25System@Classes@TComponent + 0x3d
:0071548e ; ReadState
:50161e5a ; E:\Naviplex2\rtl180.bpl
:5015b7eb rtl180.@System@Classes@TStream@ReadComponent$qqrxp25System@Classes@TComponent + 0x37
:50150b10 rtl180.@System@Classes@IsUniqueGlobalComponentName$qqrx20System@UnicodeString + 0x80
:50152464 rtl180.@System@Classes@EndGlobalLoading$qqrv + 0xc0
:501524f2 rtl180.@System@Classes@InitInheritedComponent$qqrp25System@Classes@TComponentp17System@TMetaClass + 0x66
:00714cb7 ; TCustomForm
:00411BFC Vcl::Forms::TForm::TForm(this=:03402250, AOwner=NULL)
:00536577 TfrmSelectGraphType::TfrmSelectGraphType(this=:03402250, rptWin=:04346230, dlgDefineGraph=:042F6F80)
and here is the extract of the faulty code in the dfm file:
object serPieGraph: TPieSeries
Marks.Arrow.Visible = True
Marks.Callout.Brush.Color = clBlack
Marks.Callout.Arrow.Visible = True
Marks.BackColor = clSilver
Marks.Color = clSilver
Marks.Style = smsXValue
Marks.Visible = True
Gradient.Direction = gdRadial
OtherSlice.Legend.Visible = False
OtherSlice.Text = 'Other'
PieValues.Name = 'Pie'
PieValues.Order = loNone
end
Do you have an idea of what happens ?
Re: Crash when using Pie Chart
Post by Yeray » Thu Sep 19, 2013 3:18 pm
What version where you using with RAD 2007?
Have you tried to remove line per line those you've posted to try to identify which one is causing the problem?
Does the error also appear if you create a new simple application with just a chart on the form? And adding a simple Pie?
JeffS
Post by JeffS » Fri Sep 20, 2013 12:14 pm
TeeChart 8.02 for Delphi 2007
Yes. Even if I remove all the lines except the declaration of Pie, the crash happens.
In other words, the simple fact to mention TPieSeries in the dfm file
(for intance:
end
causes the crash.
I am ashamed to say that I am not used to this kind of excercice. I am in charge of porting the application to the new version of the Embarcadero builder.
I never wrote an application using your library from scratch. But I can learn...
Post by Narcís » Tue Sep 24, 2013 8:20 am
Hi Jeffs,
JeffS wrote:Hi,
What about with latest v8 release or current v2013? Have you had the change to test them?
JeffS wrote: I am ashamed to say that I am not used to this kind of excercice. I am in charge of porting the application to the new version of the Embarcadero builder.
It's something very easy. Having a look at the tutorials included with the binary installers will help you getting started.
