Background grid as dots at major axes?
JerryB123
Post by JerryB123 » Fri Aug 16, 2013 9:01 pm
How would I get a TSeriesChart to display the background grid as single dots where the major tickmarks of the bottom and left axes would cross? (So the background would have uniformly spaced dots which would coincide with the major ticks on the left and bottom axes.)
I have searched through this newsgroup and the web, but have not found the answer to this.
Thank you.
Jerry B.
Re: Background grid as dots at major axes?
Post by Yeray » Tue Aug 20, 2013 11:12 am
Hi Jerry,
If I understand correctly what you mean, I think the easiest way to do it is using SmallDots with GDI:
uses Series, TeCanvas;
  Chart1.Canvas:=TTeeCanvas3D.Create;
  Chart1.View3D:=false;
  Chart1.AddSeries(TLineSeries).FillSampleValues;
  Chart1.Draw;
  with Chart1.Axes.Left.Grid do
    Style:=psDot;
    SmallDots:=true;
    SmallSpace:=Abs(Chart1.Axes.Bottom.Items[0].LabelPos-Chart1.Axes.Bottom.Items[1].LabelPos)-1;
  Chart1.Axes.Bottom.Grid.Visible:=false;
However, the above doesn't work for GDI+ and won't probably work as you want if you scroll or zoom in the chart. A more accurate but complex alternative would be using custom drawing techniques at OnBeforeDrawSeries event:
uses Series;
  Chart1.Axes.Left.Grid.Visible:=false;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
var bIndex, lIndex, tmpX, tmpY: Integer;
  with Chart1.Canvas do
    Pen.Color:=Chart1.Axes.Left.Grid.Color;
     for bIndex:=0 to Chart1.Axes.Bottom.Items.Count-1 do
       tmpX:=Chart1.Axes.Bottom.Items[bIndex].LabelPos;
       for lIndex:=0 to Chart1.Axes.Left.Items.Count-1 do
         tmpY:=Chart1.Axes.Left.Items[lIndex].LabelPos;
         Ellipse(tmpX-1, tmpY-1, tmpX+1, tmpY+1);
JerryB123
Post by JerryB123 » Wed Aug 21, 2013 12:14 pm
That does it.
Thank you.
Jerry B.
