Problem with the TFastLine series
Jarek
Post by Jarek » Tue Aug 06, 2013 1:01 pm
For quite unusual data but from a real life, TFastLine cannot draw a correct series. I've attached a test project.
The test project adds two points to the fast line series: one dated '2011-2-1' and second dated '2013-8-1'. Next it sets the minimum and maximum of the bottom axis (2013-7-31 23:45:00, 2013-8-1 00:00:00) what makes 15 minutes. TFastline series is visible if length of the chart is lesser than 1656px. When length of bottom axis is 14 minutes series is visible if length of the chart is lesser than 1547px.
Thanks for any help.
Jarek
TeeChartFastLine.zip
(16.06 KiB) Downloaded 388 times
Re: Problem with the TFastLine series
Post by Yeray » Tue Aug 06, 2013 3:04 pm
We haven't been able to reproduce this problem here.
We've run your application in a 1680x1050 screen and we still see the TFastLineSeries after maximizing the form, with both 15 and 14 minutes as Bottom axis range.
What TeeChart version are you using? We've made the tests with TeeChart Pro v2013.08 and RAD XE
Jarek
Post by Jarek » Wed Aug 07, 2013 12:38 pm
I'm using version 2012.07.121105.
Jarek
Post by Narcís » Wed Aug 07, 2013 4:30 pm
Hi Jarek,
Can you please try if build 2013.08.130521 solves the problem for you?
