Limit TMarksTipTool popup
I currently have a TMarksTipTool and it pops up every time the mouse is anywhere on the chart (See popup 1).
However, it only updates (calls OnGetText) if the mouse is over actual data in the graph. (See popup 3).
Is there a way to make it so that the popup doesn't happen unless it is over a data item.
Or why does it not call OnGetText before it shows every time, instead of just when it is over new data?
- Updated when mouse is over the data
- popup3.png (19.19 KiB) Viewed 22251 times
- Tip not updated unless mouse move over item
- popup2.png (20.7 KiB) Viewed 22246 times
- Tips shown when not on graph data
- popup1.png (18.39 KiB) Viewed 22232 times
Re: Limit TMarksTipTool popup
Is that a TBarSeries? I've tried to reproduce the problem here but the code below seems to work fine for me:
I see the popup only when I stop moving the mouse over a bar, and not over an empty space in the chart.
I've also tried assigning a dummy OnGetText event:
But I get a similar result. The popup is only shown when I'm over the series.
uses Series, TeeTools;
Chart1.View3D:=false;
Chart1.AddSeries(TBarSeries).FillSampleValues;
Chart1.Tools.Add(TMarksTipTool);
with Chart1.Tools.Add(TMarksTipTool) as TMarksTipTool do
OnGetText:=MarkTipsGetText;
procedure TForm1.MarkTipsGetText(Sender:TMarksTipTool; var Text:String);
Text:='hello';
There are several things in the cart. The one producing the bars is an Area.
- chart2.png (51.38 KiB) Viewed 22202 times
- Chart1.png (53.77 KiB) Viewed 22219 times
I tried now with this code and the MarkTips tool still doesn't appear when I'm above a part of the chart without any series drawn:
Pleas, arrange a simple example project we can run as-is to reproduce the problem here.
uses Series;
Chart1.AddSeries(TLineSeries).FillSampleValues;
Chart1.AddSeries(THorizLineSeries).FillSampleValues;
Chart1.AddSeries(TAreaSeries).FillSampleValues;
Chart1.AddSeries(TPointSeries).FillSampleValues;
Text:='hello';
Here is a simple Form that has the problem.
It doesn't start showing the popup text right away, you have to scroll over a bar for a while first and then move back over the empty space.
It calls the GetText every time you go over a bar, but just displays the last one when you are over the empty area.
Didn't accept the dcu and dfm, so I put it in a zip.
- TChartTest.zip
- formMain
- (5.43 KiB) Downloaded 1002 times
Hi INL2,
.dcu files are not necessary, they are generated with the compilation process. However, the .pas files are necessary. Could you please also send form's .pas and, if possible, project's .dpr?
Sorry, I meant to send the .pas, lets try this again.
- MainFiles.zip
- (3.44 KiB) Downloaded 921 times
The project uses TestForm unit that isn't included in the zip. Since I saw FormMain2 is included but not used, I changed one for the other. If I deactivate the series that don't have a MarkTips tool assigned, it seems to work fine. Could you please confirm this?
Still has issues for me.
(See pictures)
The # in the popup is the same.
It pops up when not on the bars.
I remembered we are a version behind because we had some conflicts with your latest version. Is this an issue that has already been fixed.
(See pictures)
- GraphPic2.png (54.28 KiB) Viewed 22063 times
- GraphPic1.png (54.2 KiB) Viewed 22068 times
The issue is much simpler. It's just a problem of having 2 area series in a chart with an associated MarkTips tool each. You can reproduce it with the attached project. I think this is a bug and added it (TV52016624) to the defect list to be fixed for future releases. The solution is pretty simple though, you should just have a single MarkTips tool for all series, not associated to any particular series.
- MultiMarkTips.zip
- (2.75 KiB) Downloaded 949 times
Sorry for the long delay, but project got postponed.
If I make one MarkTips for all the series, how do I know what series I am dealing with inside the function MarkTips___GetText(Sender : TMarksTipTool; var Text : string)
Since sender.Series is nil when you have the "Mark Tips" "Series" assigned to "(all)"
You could know it doing something like this:
procedure TForm1.ChartTool1GetText(Sender: TMarksTipTool;
var Text: String);
var i: Integer;
MousePos: TPoint;
MousePos:=Chart1.GetCursorPos;
for i:=Chart1.SeriesCount-1 downto 0 do
if Chart1[i].Clicked(MousePos)>-1 then
Caption:='SeriesIndex: ' + IntToStr(i);
exit;
