TChartWalls.Create - No overload found
SR_Developer
Post by SR_Developer » Fri May 31, 2013 8:55 am
Trying to compile an old project with new VCL2013 PRO.
But in Chart.pas I can't seem to get passed TChartWalls.Create where
FBack:=TChartBackWall.Create(FChart);
gives me a : [dcc32 Error] Chart.pas(2274): E2250 There is no overloaded version of 'Create' that can be called with these arguments
By lib path points to the source code and I have include VCLTee in Unit Scope Names for project
If I don't include VCLTee then I get stuck in TeCanvas.pas in TTeeCanvas.TextOut where there is a difference between types (VCLTee.TeCanvas.TTeeCanvas vs TeCanvas.TTeeCanvas) first param for HtmlTextOut.
I have tried whit an new empty project where I just add Chart in uses with the same result.
Compiler: XE4
Any ideas
/Jens G
Re: TChartWalls.Create - No overload found
Post by Yeray » Fri May 31, 2013 2:37 pm
Hi Jens,
First of all, try adding the "\Sources\compiled\Delphi18.win32\Lib" path in the library path and move it to the top.
Remove the other TeeChart references (or just add a point at the beginning of the path to turn it grey).
Does a simple project with just a chart work fine?
Then, if you want to directly use the sources in XE4, remove the path added above and add the "\Sources\VCL" and "\Sources", and move them to the top, keeping that order so the IDE will find the VCL folder before.
SR_Developer
Post by SR_Developer » Mon Jun 03, 2013 6:26 am
Using the compiled path worked. Thanks for the tip.
But that means that the source can't compile???
/Jens
Post by Yeray » Mon Jun 03, 2013 9:05 am
Hi Jens,
SR_Developer wrote:But that means that the source can't compile???
No, of course you can use the sources directly. The first part of my last post was intended to give you an alternative to build your projects using TeeChart.
The second part of my last answer is the option to follow to compile your projects directly using TeeChart sources.
